Power steering pump
Rating: Thread Rating: 3 votes, 5.00 average.
Old Sep 9, 2012 | 06:02 PM
F17RAK's Avatar
E55K AMG
Power steering pump
Hi guys i am a fellow E55 owner from over the pond, but i am new to this forum, was wondering if anyone can help me?
I was doing some donuts & power slides the other day, (as you do) and now my steering is so heavy that i can hardly steer the car. I have been told that i need a new power steering pump.
Just wanted to know what other models of mercedes use this same pump? Im guessing that its not amg specific.
Cheers!
Old Sep 9, 2012 | 09:46 PM
GT-ER's Avatar
2005 E55 AMG
Apparently almost all of them. My pump died and used a pump that was laying around in my friends shop, he said it came off a V6 car or something. I know my wifes ML350's pump looks identical to mine ( reservoir is different though ).
BTW- install a new reservoir since it has a built in filter.
Old Sep 10, 2012 | 08:03 AM
F17RAK's Avatar
E55K AMG
ok cool, well suppose i better take the old one off & then go on a hunt.
Is it easy enough to take install? Also cant i re-use the original reservoir?
Old Sep 10, 2012 | 08:15 AM
GT-ER's Avatar
2005 E55 AMG
Do not reuse the reservoir. If the pump failed then the reservoir filter should be clogged with metal particles.
Install wasn't that bad, the reservoir for some reason didn't want to go back on and was a huge pita but everything else was ok.
Old Sep 10, 2012 | 09:26 AM
F17RAK's Avatar
E55K AMG
Thanks dude, youv been a massive help. I read an old post of yours, you sed you got one for free, what car was that from? I only ask because in the uk there isnt many petrol powered mercedes available, mainly diesel.
Old Sep 10, 2012 | 09:41 AM
GT-ER's Avatar
2005 E55 AMG
No problem.
That's the pump I mentioned in my post above, I'm not sure what car it came from.
Old Sep 10, 2012 | 11:45 AM
F17RAK's Avatar
E55K AMG
can anyone get me a part number?
Old Sep 10, 2012 | 04:53 PM
F17RAK's Avatar
E55K AMG
GT-ER, does this look correct?
http://www.ebay.co.uk/itm/Mercedes-E...#ht_500wt_1288
Old Sep 10, 2012 | 05:14 PM
F17RAK's Avatar
E55K AMG
or is it this?
http://www.ebay.co.uk/itm/MERCEDES-E...ht_1018wt_1037
Old Sep 10, 2012 | 05:32 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Contact
http://www.mslcentre.biz/ ask for Aceed
Old Sep 10, 2012 | 06:02 PM
GT-ER's Avatar
2005 E55 AMG
Neither, look for w211 pumps.
Old Sep 11, 2012 | 05:39 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
As Shardul says, speak to Aceed (Acid) and he will sort you out, he is based in Birmingham too.
Old Sep 11, 2012 | 10:19 AM
F17RAK's Avatar
E55K AMG
thanks guys,just waiting for acid to get back to me. But i think i found the right one,
http://www.ebay.co.uk/itm/MERCEDES-M...item3cca41d4c9
Old Sep 11, 2012 | 10:34 AM
GT-ER's Avatar
2005 E55 AMG
Yep, that one looks right.
Old Sep 11, 2012 | 10:58 AM
skratch77's Avatar
2005 E55
is that whine when we start up the car cold the power steering pump?mine does the whine all the time now and trying to figure out if its the pump or something else
Old Sep 11, 2012 | 11:11 AM
saleen01's Avatar
2004 E55
i have this problem also, noise goes away after a minute...
Old Sep 11, 2012 | 11:44 AM
GT-ER's Avatar
2005 E55 AMG
Nope...oil pump.
Old Sep 11, 2012 | 12:09 PM
skratch77's Avatar
2005 E55
Originally Posted by GT-ER
Nope...oil pump.
you think I should change it or is it normal
Old Sep 11, 2012 | 02:09 PM
saleen01's Avatar
2004 E55
oil pump? noooooooo...come on?
it only happens to me when the car is cold and i back out and turn the steering wheel, at initial startup during idle...no noise...
Old Sep 11, 2012 | 04:10 PM
F17RAK's Avatar
E55K AMG
Spoke to acid today, nice bloke, knows his stuff. Found out that i can get a brand new pump for around £170.
Even saw & heard his estate (station wagon).
Old Sep 13, 2012 | 03:28 PM
F17RAK's Avatar
E55K AMG
Decided to tackle the pump myself, took it out to find out part numbers. Wasnt that difficult.
£167 brand new, cant moan at that. Here som pictures to help others.
The parts database shows its the same as the cls55 ( obviously) also the 500 engines.
Old Sep 13, 2012 | 05:10 PM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Nice! Prob should change my res also have 68k miles on it
Old Sep 13, 2012 | 06:23 PM
berti_00's Avatar
2016 Cls63s AMG
I bought one to do it...
Old Sep 13, 2012 | 06:41 PM
F17RAK's Avatar
E55K AMG
reservoir bottle doesn't cost much, that should be here tomorrow straight from mercedes.
Old Sep 23, 2012 | 08:15 AM
F17RAK's Avatar
E55K AMG
I changed my oil pump, new reservoir & new o ring. But its leaking from the rear o ring connection. Taken it out twice but still wont stop leaking. I used this oil
http://www.ebay.co.uk/itm/Carlube-Sy...item3a76653ab1
Is there a trick to this, is the bleeding process critical? Does the wrong oil make it leak? Even though i was told its the correct fluid.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
