200mph speedo
Rating: Thread Rating: 2 votes, 5.00 average.
Old Sep 29, 2012 | 07:28 PM
marc.l's Avatar
2003 E55 estate
200mph speedo
Changing to a 200 mph speedo from a 160 mph is it a case of just fit it and have it programmed in star ?
Old Sep 29, 2012 | 07:40 PM
vdubpower's Avatar
i drive them all, fast and hard
Y r u doing it
Old Sep 29, 2012 | 07:49 PM
marc.l's Avatar
2003 E55 estate
Had the vmax removed and will be doing an event like your Texas mile .
Old Sep 29, 2012 | 08:35 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
flash replacement speedo to zero or install a new unit from what I understand. Then use star to transfer.
Old Sep 29, 2012 | 09:58 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
From what I understand another member just removed one of the pc board from his original cluster and put it in the used 200mph cluster and everything worked. The mileage was transferred also. I have pictures of what he did they are on my work computer I will post them up later on.
Old Sep 29, 2012 | 11:11 PM
AMGPilot's Avatar
2004 E55
When you do your star programming you also need star developer to program the spedo to be "Non Linear" otherwise your speedo will show 200 when you are doing 160
or maybe you want to play that game
Old Sep 30, 2012 | 12:57 PM
SavMan's Avatar
2004 E55K AMG Wagon
I went the same route as Pearlpower suggest, the cluster was flashed to zero mileage so when connected to my car the mileage updated automatically. Star was needed to program all the options (lighting etc). Sorry cant say what was used to flash the mileage as the guy selling it had already flashed it.
Old Sep 30, 2012 | 01:27 PM
berti_00's Avatar
2016 Cls63s AMG
i installed mine of a cls63 but my milage doesnt show... everything else is perfect am still trying to figure that out
Old Oct 1, 2012 | 02:59 PM
93RX7LSX's Avatar
93' Ultrasonic Blue Mica LS6/T56 RX7 R1 weekend/ 2007 4Runner V8/ 08' prius
Originally Posted by vdubpower
Y r u doing it
Because it's super cool to go 200mph.
Old Oct 1, 2012 | 03:09 PM
shardul's Avatar
with compliments from Nealgobert
Old Oct 1, 2012 | 03:13 PM
marc.l's Avatar
2003 E55 estate
The uk amg has white faced dials , and a 160 mph speedo , as I like to drive around at 180 at the very least I decided to change it .*
*Real reason I picked up a black faced 200 mph cluster for £40
Old Oct 1, 2012 | 03:14 PM
marc.l's Avatar
2003 E55 estate
Thanks you very much Shardul much appreciated !!!
Old Oct 1, 2012 | 03:19 PM
vioilio's Avatar
2003 E55 AMG
The cluster you will be installing needs to be either:
1. NEW
2. If used flashed back to 0 miles.
Before you take the original cluster out you MUST have Star with DEVELOPER MODE!
Go into the developer menu of Star diagnose after you have entered your current instrument cluster and then you take simple digital pictures of all the different variable settings that you see in the sub menus under READ CODING AND CHANGE IF NECESSARY after you have pictures of all those variables you can connect the new instrument cluster...disregard the message about the cluster not being assigned to the car and tell star diagnose NOT to do initial startup...go to the regular READ CODING AND CHANGE IF NECESSARY (not in developer mode but in regular mode) and CHANGE ODOMETER READING (however that is called) - and make the new instrument cluster adapt the mileage from the ignition switch (EIS)...if the star diagnose is able to read the values properly, it will show the mileage in the IC being 0 and the mileage in the EIS being what it is and you confirm the reading...if the star diagnose shows that it is unable to read the odometer reading you have to stop right there and go a different route
After the new IC took the odometer reading you will have to set the date of production (to be taken out of EPC or from your car registration papers) once you did that you can go back into the developer menu - to READ CODING AND CHANGE IF NECESSARY and change all variables to make them match the old E55 IC variables...you will notice that there are some extra/different/missing variables but it will all become clear when working on it.
Old Oct 1, 2012 | 03:38 PM
marc.l's Avatar
2003 E55 estate
Thanks violio, the one I've purchased looks like this
http://imageshack.us/photo/my-images...ct01203302.jpg
Also found this one
That's a whole consul and its cheap !
Old Oct 1, 2012 | 04:12 PM
vioilio's Avatar
2003 E55 AMG
That is a CLS63 amg cluster which I installed in my 2003 E55. The new cluster added some new cool features such as: oil temperature, battery voltage, lap timer.
Old Oct 1, 2012 | 04:25 PM
marc.l's Avatar
2003 E55 estate
http://imageshack.us/photo/my-images...ct01203425.jpg
Missed the link off ...
That's the look I want , far better ( my op) than the stock white .
Old Oct 1, 2012 | 04:38 PM
efiftyfizzle's Avatar
W212 E63 AMG S Model
You should paint the silver back-plate black to match with the cluster.
Old Oct 1, 2012 | 04:52 PM
vioilio's Avatar
2003 E55 AMG
Brabus cluster is what I want too, but I have better chances wining the lottery than finding one for sale
I ordered it specifically with the aluminum bazel because I like it this way better. It matches my silver car and shifter trim perfectly.
Old Oct 1, 2012 | 05:01 PM
marc.l's Avatar
2003 E55 estate
My local mb dealer has one in from a genuin brabus ( was swapped when they sold the car) I can have for £160
Old Oct 1, 2012 | 05:36 PM
vioilio's Avatar
2003 E55 AMG
I WANT IT!! CAN YOU GET IT FOR ME?
Old Oct 2, 2012 | 09:25 AM
marc.l's Avatar
2003 E55 estate
I'm seeing the parts guy at the weekend and we are going through the dealers old part stock . At one time if they took a car in with upgrades they put it back to stock before reselling due to the MB warrenty .
Wil give you a list of what parts he has .
Marc
Old Oct 2, 2012 | 09:46 AM
vioilio's Avatar
2003 E55 AMG
Marc
I really appreciate your time and help! If there is any chance to get me that cluster it would be AWESOME!
Old Nov 24, 2016 | 01:16 AM
gazosnic's Avatar
e46 m3, w211 e55
Thanks for this post. I just installed a E63 cluster in my E55 this way and it worked great. No need to program anything. I did notice however I didn't seem to get the extra features others have mentioned (e.g. lap timer, additional oil temp gauge etc.). Anyway to enable this without STAR?
Old Sep 20, 2019 | 10:20 PM
jnarkaj's Avatar
2004 E55
hello everyone i recently swapped out my speedo for an e63 speedo. i swapped the pcb so i have retained the old mileage but my issue is the speedo reads 200mph when im doing 160mph. does anyone know how to fix this?
Old Sep 23, 2019 | 10:05 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
That sounds like you just need to have your speedo recalibrated. I don't know the procedure, but you already know this.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
