2004 e55 ignition issue
Old Oct 5, 2012 | 04:36 PM
startrac100's Avatar
2004 Mercedes e55 amg
My dealer says our E-55 needs a new ignition at $ 1100. I bought the car new, jsut now has 70K miles, always serviced(was serviced two weeks ago no error codes) prior to that I let it sit for 6-8 weeks everything worked when I parked it. I put the key in then turned...nothing(would not turn over..nothing). I then took the key in and out 2-3 times, it started as if nothing was the matter(no error codes) I drove it a couple hundred miles. It still did the same thing infrequently. Sometimes it would start first turn even 10 times in a row then would do the same thing again. Took it back to my dealer, $ 1100 for new ignition. They also said main battery low as well from 2 weeks ago when it was in and needed 300. Car never displayed any warning or trouble lights on dash even when I took it in. At the same time I now find its costing me $ 650 for a heater issue where the aircond works but heater would not blow hot air, they said a bypass needed replaced? At 70K miles it seems pretty early to have to replace an ignition. Between the ignition, heater issue and battery its over $ 2K. I have owned 50 cars, suv's and trucks never had an ignition replaced. Anyone else have this issue?
Old Oct 5, 2012 | 04:38 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
The ignition system consists of several components. Please be specific as to what part they are saying is faulty.
Old Oct 5, 2012 | 04:57 PM
e55 ignition
I think the code was 9030? I just received a call from the dealer they think it now may be the starter (yes they tested it, showed Ok). It appearently made a click when they turned the key this time, possibly false code? Two weeks ago they could not replicate the not starting, fired right up, no error codes. Hopefully its a starter verse replacing an $1,100-1,200 ignition.
Old Oct 5, 2012 | 05:05 PM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Find a good independent mechanic. You'd have saved a TON on the heater repair (likely a common valve that went bad that's a bit of a pain to get to) and the battery who knows what happened there. An independent will save you a TON of money on repairs.
Old Oct 5, 2012 | 05:28 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Intermittent problems are tough. Could be a safety switch or a relay. As HAL said: I think you should wait for it to fail.
Old Oct 5, 2012 | 05:40 PM
The engine will not crank(turn over) or anything(when it is messing up) so I take out the key and place it back in a couple of times and starts up absolutely 0 hesitation. It may start 10 times no issue then here it goes again. They replicated it at the ddealership a few times. Just a weird issue I guess. I dont think its the crank position sensor as it does not turn over at all or it starts up perfect. I will keep everyone posted as what it turns out to be.
Old Oct 6, 2012 | 12:07 AM
mbslowner's Avatar
2003 SL500 AMG Package, 2015 C300, 2016 WRX
startac100 give this guy a call at 708/268-3800. His name is Carmine and he is specialize only in Mercedes and great. He could save you tone of money and is honest. I always go to him for any services. His dad has been working for MB dealer for 20 plus years. You tell him that Clint refer.
Old Oct 6, 2012 | 12:23 AM
E55Greasemonkey's Avatar
This place is a joke.
Have you first tried another key?
Old Oct 6, 2012 | 06:48 AM
FASN8N's Avatar
CTSV/6sp Grocery Getter
The ignition issue is most likely an alternator or voltage regulator that is bad
