Another post of dissaponting dyno numbers today..
The ECU reset helped today, the power is there, or more like the "horsepower" is there but the off idle torque is not. I was able to brake the tires loose @ 40 MPH even with the drag radials (ESP off). The car "felt" faster before, similar to how the e55 feels faster than the E63 but they are the same in the 1/4.
Can't wait to get dyno numbers and head back to the track.
The car had been cooling for several hours, but the first 2 botched runs heated it up.
Was the car just ran again right after adjustments were made or did the car get cooled down? Just curious if the hp increase was from an actual improvement or just from cooler car. Time to head back to the track
Today is "Funday Sunday" at Orlando Speedworld drag strip. Opened at 10am and $15 to run! Get some! haha Open again this Friday. How far are you from that, must be close right?
The car cooled a little on the dyno between adjustments, they had a pretty strong fan there. It gets pretty hectic when other people are waiting, the supercharger is off, the new software is not coming through email as fast as it should, everyone's asking questions and I'm stressing out about the numbers hahah...I can say, without a doubt as soon as I drove off the dyno and down the street the difference was huge, it was like the difference between 80F weather and 60F weather on the butt dyno. Actually I got a headache right after from the G-force and the blood rushing in my head lol.
Orlando Speed World is about 30 miles away, not bad. Can't make it today but I can try for Friday. Sadly, it looks like they are closing at the end of 2012, unless someone else takes over the operation.
Never had the ability to cool the engine much, logged my IATs on last run and were starting at around 90+ and hit 160 @ 120mph.
Outside temp per cluster was 66F but wet mist and fog.
I haven't had time yet to split the intercooler system and install my rear tank.
For reference, a stock CLS63 TT with the performance package ran 12.1 @ 119 in front of me on my last run. I also dropped the AMG hammer on a 2011 GT500, he ran 13.02@114.13. I ran 12.01@116.22. For reference, that GT500 traps 117mph per Car+Driver.
I will try to get back on the original dyno at some point but its very difficult to schedule with them.
There never was good traction, even the 9 second cars were running 11's
Tried many different launch techniques, ESP on/off, always in raised mode, holding RPM from 1000 to 1800, easy on the gas, slamming the gas, Jphn Force stlye burnouts, didn't matter much.
The car is amazingly consistent though. Check the timeslips for 11.973,11.974,11.974 each one hour apart!!
My goal is a consistent 11-second car. I think the 82mm and LSD will help a lot.
I split the cooling system Friday before I headed to the track, no resevoir as I ran out of time, just used a length of hose to fill and bleed. I will be adding a second small heat exchanger and small holding tank later on.
Still impressive times for a heavy 4 door with 2.65 gears.
