Wheel fitment Guru's help!!
Looking at picking up a set of wheels and need to know if these will fit my 03 E55. They are HRE 540R's They are 19x8.5 ET35 and 19x10 ET38. I used the wheel offset calculator and it says fronts will have 11.35mm less clearance inside and extend 1.35mm from the outer, will that fit?? Rears inner clearance is 11.7 less and extend outer by 13.7mm. I don't want them to stick out of the wheels wells either. I think it should be okay but just want some others opinions
2009 W211 E350 AMG Sport PKG
i dont know much about wheels but by the sound of it seems like the fronts will be nice and snug. the rears you can just have an alignment shop run custom negative camber or have a wheel shop shave the back pad. if its a steal of a pickup i would just scoop it up and try to work with it. they're 3 piece wheels so you can swap out barrels to make them fit.
i'm running r321 SL HRE's on my non-amg w211 and my wheel guy is going to help me fit them. 20x10f 20x11r offsets tba.
