Which 82mm Throttle Body to Mate with Needswings CAI
05 E55, 07 ML500
Looking at a new 82mm Throttle Body.. As you can see in my sig I have a Needswings CAI, does it matter which TB??
Looking at TTM, EC, and FTP.. Any help is greatly appreciated...
1 Post
2004 E55K AMG Wagon
How long have you had the Needswings CAI? They only recently shipped a Y-Piece that would fit so you might want to check the diameter of your Y-Piece. My 82mm TB outer diameter is 3 9/16ths Inch.
05 E55, 07 ML500
Savman,
I've had it a couple of month's.. Spoke with Rob at needswings and he indicated that he will give the new Y pipe that fits the 82mm throttle body, all I have to do is send him back my current Y pipe...
Which 82 TB are you using??? How was the install? Did you need an adapter plate?
1 Post
2004 E55K AMG Wagon
Savman,
This is the part number A2731410325, I do have an adaptor plate and the Needswings fit is tight. I had to cut a good inch of the Y-Pipe to clear the bulkhead.
Savman,
