ESP malfunction... NEED HELP
Old Oct 23, 2012 | 11:02 PM
nizzle's Avatar
2014 AMG E63S, 2006 XK8 victory edition convertible, 2006 supercharged trailblazer SS, 2001 E430
My 1st MB is turning out to be somewhat of a problematic nightmare. It is a 2004 E55 AMG and the problem THIS TIME is I am now getting a ESP malfunction message, then it reads distronic. If you shut the car off and start it again, the message goes away. The car will drive but as soon as you try to accelerate any harder the just "regular" driving, it wont let you get full power and the messages appears again. When the messages are on, the car drives sluggish and switches thru gears rapidly. I am gonna take it to the shop soon but just wanted to know if anyone had any ideas of what this issue might be.
Old Oct 23, 2012 | 11:49 PM
black06c230's Avatar
mgLipGD
does the CEL come on at all? and does the car pull hard to one side when accelerating ?
Old Oct 24, 2012 | 01:54 AM
03'55AMG's Avatar
AMG
Try starting the car, and turning the wheel ALL the way to the left, then ALL the way to the right. This is how to calibrate the ESP when the car is reset. Hope this works for you!
Old Oct 24, 2012 | 10:13 AM
nizzle's Avatar
i will try that and report back. thank you
Old Oct 24, 2012 | 11:04 AM
nizzle's Avatar
Tried it, the issue is still there. Thanks for the suggestion tho. Also, I found out the car is actually going into limp mode when the codes pop up.
Old Oct 24, 2012 | 11:07 AM
nizzle's Avatar
I am not sure if a CEL comes on. It just reads ESP malfunction, distronic. Then after a second, it just reads "2 malfunctions". Is there a way to see if there are CEL's without a scanner? No hard pull to one side or another either.
Old Oct 24, 2012 | 11:42 AM
Forrest Gump 9's Avatar
shrimp boat
Disconnect the main battery for ten minutes. That will solved 90% of the electrical problems on these cars.
Old Oct 24, 2012 | 12:44 PM
nizzle's Avatar
Ok I'll try that too.... we'll see what happens
Old Oct 24, 2012 | 02:07 PM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Camshaft sensors
Old Oct 24, 2012 | 02:14 PM
nizzle's Avatar
Originally Posted by Manuyc
Camshaft sensors
I hope not
Old Oct 24, 2012 | 02:20 PM
Manuyc's Avatar
I hope not
Same thing happened to my BMW 540 it went into safe mode and it was the two camshaft sensor, the car would barley drive and when I turned it off and turned it back on it would drive for a bit then limp again, but eBay they are cheap or parts geek .com has them for cheap
Good luck
Old Oct 25, 2012 | 11:16 AM
nizzle's Avatar
I Found "the" or at least "a" problem. The SC belt slipped off. But now the question is...... why?
Old Oct 25, 2012 | 11:35 AM
Manuyc's Avatar
Depending if you have a lot of miles the motor mounts are part hydraulic so that can be an issue from to much torqu your mount is worn and the engines lean more to one side and thE belt can slip off. That is only my assumption to check it out
Or your pulleys can be going they are plastic and they brake after a while. It's cheap and easy to change
Old Oct 25, 2012 | 11:38 AM
nizzle's Avatar
68k on the car. I am thinking maybe belt tensioner or idler
Old Oct 25, 2012 | 11:40 AM
Manuyc's Avatar
Also ask shardul form member he is a genius on these cars he can really help you
Old Oct 25, 2012 | 12:25 PM
nizzle's Avatar
I will. He and I have talked a few times. He has provided me with much useful info.
Old Oct 25, 2012 | 12:35 PM
Manuyc's Avatar
Old Oct 25, 2012 | 12:45 PM
Manuyc's Avatar
Make a lot of sense
Old Oct 25, 2012 | 02:50 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
check the following for play
1. SC tensioner pulley
2. Double idler pulley (metal and plastic one)
From what I have seen once the double idler begins to fail it starts throwing the belts off. ASP idler set is a cheap alternative to OEM replacement pulleys.
Old Oct 25, 2012 | 03:08 PM
nizzle's Avatar
Hey hey. Speak of the devil . Thanks for stopping in.
1. It only threw the SC belt. Would that be consistent with the double idler issue?
2. Is ASP any better or lesser as far as quality vs OEM?
Old Oct 25, 2012 | 03:21 PM
shardul's Avatar
If the front metal one has some wobble it may throw a belt.
Old Oct 25, 2012 | 08:34 PM
cdsjklee's Avatar
2004 SL55 AMG EUROCHARGED. 2002 X5. 1999 SUBURBAN WHIPPLE SUPERCHARGER+MODs,04 M3 EUROCHARED
Do you have smaller S/C pulley and tune?
I have a 04 SL55 I have same problem . ESP malfunction visit work shop message shows right after S/C pulley installed and new tune.
The shop installed Pulley can not find why. Car does not have to move to get ESP malfunction message just turn on the car and depress gas pedal then ESP Malfunction messages shows. just like yours turn off the car then it resets itself. Star sysytem shows ESP does not commucate with Engine control unit. Shop thinks it may caused by tune So Contacted Eurocharged but they think it is not caused by Tune so Tomorrow I have an appointment at MB dealer to check it out. It maybe just coinstance but it happened right after the S/C pulley and new tune and I never had this problem before.
Old Oct 26, 2012 | 12:11 AM
nizzle's Avatar
No SC pulley but i have a crank pulley and a tune. HOWEVER, mine just threw the belt for some reason
I put the belt back on and drove it a couple miles and everything appears to be kosher. I didnt romp on it too much but I'll give it a good driving here this weekend.
Old Oct 26, 2012 | 01:48 AM
cdsjklee's Avatar
Did you try to Turn the ignition on and press the gas pedal to see if that triggers the ESP malfunction message on.
Old Oct 26, 2012 | 11:44 AM
nizzle's Avatar
Nope. I just put the belt back on and everything seems fine for the moment.
