O/T. Engine gurus advice needed
Me and a few friends decided we wanted to build a nice little street car, but have disagreements on engine setup. We can get the following engines: an older Ls1, a Chevy 302, a 350 (forgot brand), or a 4.3 liter out of a mustang gt. Our goal is 700 crank HP. We are open to forced induction or cheater juice (or both), but would prefer to keep stock internals. Thoughts?
4.3L isn't from a mustang. LS engines are by far the cheapest and easiest to make tons of power with.
I like the diesel idea lol. I've got a cummins making around 600hp and over 1300 ft/lbs of torque and drive it daily and tow with it. I've gone a 7.8 in the 1/8 at 8000lbs so far. Now I've got a 66mm single turbo so with enough fuel ill be in that 700hp range.
We are getting the engine we choose for free, and I think we have some cheater juice kits we are getting so that leaves about $2-3000 in our budget. We were thinking about using an older Camaro body for the project.
Looking at your engine choices, I think you are confusing them. Most likely a Ford 302, Chevy 350, and the 4.3 sounds like another GM motor unless you meant a 4.6 from a.Mustang. I would go with the LS1 or the 4.3(if its the straight 6 ).
You mentioned budget...how much is set aside for braking and safety components?
2003 porsche 996 turbo
try to think outside the box. everyone in town has a camaro or stang or vette they run. hoo hum. maybe a 240 z with a v8? an old vega or s10 pickup? i saw a guy with a 60's pickup and a cummins diesel that had over 1300 ft/lbs of torque. massive wheelies on every launch!
also saw a guy with a nissan 240sx and put a new 6.0 gto motor in it. he said it was almost a drop in!
We already have some safety equipment set aside, the only thing we need is brakes(need the car first), and a roll cage of some sort, but we need a car for that too. We have bucket seats with 4 point harnesses, some fire extinguishers, and we plan on having abs as well as traction control.
