Running lean on highway
Old Oct 28, 2012 | 06:05 PM
SavMan's Avatar
2004 E55K AMG Wagon
3 times today had the following
Driving with traffic flowing 65-80 mph light throttle then a hesitation, noticed AFR signals lean and no matter what throttle position was showing 16-18 !
Pulled over and car was erratic idle, checked for codes and nothing. Switched off restart and all is OK but will then repeat 20 miles or so later.
3rd time checked fuel trims before shutting down and short trim banks 1 and 2 show +15% but 02 sensors and wideband show lean. Still no codes.
A few days ago I had the throttle body and fuel rail/injectors off but surely a fitting issue would show up at other times not just highway driving?
Old Oct 28, 2012 | 07:02 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
It sounds to me like the SC clutch is locking up and then not unlocking when it should.
Old Oct 28, 2012 | 08:36 PM
GT-ER's Avatar
2005 E55 AMG
Check fuel pressure. My friend had this happen and his fuel pressure was 30psi. Swapped the pump and it went up to 80psi.
Old Oct 28, 2012 | 08:37 PM
GT-ER's Avatar
2005 E55 AMG
Unlikely as it's default position is unlocked so the ECU would have to tell it to lock and the ECU would be able to compensate for the extra airflow anyways.
Old Oct 28, 2012 | 09:12 PM
PACougar's Avatar
Well, I've had it happened and verified it with STAR. I can assure you it isn't able to compensate for it under light throttle or at idle. When I've had it happen the symptoms are identical to what the OP described.
Old Oct 28, 2012 | 11:12 PM
GT-ER's Avatar
2005 E55 AMG
Weird no doubt. Easy to check at least.
Old Oct 28, 2012 | 11:34 PM
PACougar's Avatar
Trust me if anyone has had weird problem, I've probably had it too. In my case the problem had to do with the vacuum before and after the TB upsetting the ECU.
Old Oct 29, 2012 | 03:40 AM
SavMan's Avatar
2004 E55K AMG Wagon
Well get that checked but at 80mph surely the supercharger must be engaged anyway as the RPM would be >2200.
The weird thing is the way the AFR flips so violently from hovering around 14.5-15.2 then the stutter and AFR registers off the scale. With increased throttle it flickers around 16-17 but will not return. Injector Duty Cycle remains the same at 10% but as said earlier short fuel is then +15% but both the 02 primary sensors and my wideband show the exhaust is lean.
Old Oct 29, 2012 | 04:05 AM
PACougar's Avatar
The supercharger engages based upon engine load, not RPM so when you're cruising on the freeway it most likely isn't engaged. Also the stutter you mention may be the clutch locking under to light of a load. Does the car jerk like a torque converter locking up?
Old Nov 1, 2012 | 05:38 PM
SavMan's Avatar
2004 E55K AMG Wagon
PACougar
Thanks, it was the clutch sticking on. I just had the S/C Pulley Clutch fitted a couple of weeks ago and it was checked in the workshop and run up to working temp. However when the car is driven for longer periods the additional heat causes expansion and the pulley catches and stays on. Looks like I need to put another shim in there.
Old Nov 1, 2012 | 06:13 PM
PACougar's Avatar
PACougar
Not a problem, I'm glad this fixed your problem. I know how frustrating it can be! Now go set some freaking records in the wagon
Old Nov 1, 2012 | 06:16 PM
SavMan's Avatar
2004 E55K AMG Wagon
The worst part is we were told fit all four shims but then it looked like 3 would be OK
Old Nov 1, 2012 | 06:36 PM
PACougar's Avatar
Hopefully you have one with the updated spring straps, because the ones that were made of mild steel instead of spring steel stretch out and the clutch's clearance will change.
