RedBullJnky, Kustom2K1, and amx1397 met at PBIR last night
Old Nov 9, 2012 | 07:40 PM
kustom2k1's Avatar
03SL55
Good luck E..tear that place up!!
Old Nov 9, 2012 | 07:43 PM
amx1397's Avatar
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
damn, if i wasn't going on a day trip early in the morning, i would be there.jim
Old Nov 9, 2012 | 07:52 PM
alextaylor29's Avatar
2004 E55 AMG
Congrats, great runs all around!
Old Nov 9, 2012 | 10:19 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Very nice times, you guys are flying! You adding more mods before mir? Maybe a light wheel drag pack or something else?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Nov 9, 2012 | 10:43 PM
Forrest Gump 9's Avatar
shrimp boat
Originally Posted by RedBullJnky
On the way to PBIR right now in full race mode. Car just dynoed 549/593. We will see.
Good lucks, but any update??
Old Nov 9, 2012 | 11:13 PM
RedBullJnky's Avatar
you to Hate
First run didn't get timed. Don't know what happened.
Second run:
Third run the trans went into limp mode.
Was not as cold as Wednesday night.
Old Nov 9, 2012 | 11:44 PM
  #32
shrimp boat
it's like a broken record, sooooo close.
What tires pressure do you run?
Old Nov 10, 2012 | 05:55 AM
  #33
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
That just ain't right!
Old Nov 10, 2012 | 12:03 PM
  #34
Jimshorts's Avatar
'05 SL65, '13 FX4 Eco
So damn close... Toss a 25 shot on there lol.
Wednesday was really cold though was down in ft lauderdale/Miami for a few days. Never thought I would get sick of seeing maseratis.
Old Nov 10, 2012 | 12:06 PM
  #35
e55amgrocket's Avatar
Dirt Scooters
You will get it at MIR don't worry. 7.07 in the 1/8 should of got you that 10 second slip. Did IAT's get high and pull any timing?
Old Nov 10, 2012 | 09:12 PM
  #36
you to Hate
Thanks! maybe adding a SC pulley, skinnies, and braile battery. Battery wasn'y in for these runs.
You should have hit me up.
Not sure. I'm going to turn up meth and have it spray earlier.
And thanks to every one for the kind words!
Old Nov 10, 2012 | 09:25 PM
  #37
amx1397's Avatar
1, 2, 3, go.
I got something for you, jim
Old Nov 10, 2012 | 09:31 PM
  #38
you to Hate
Originally Posted by amx1397
1, 2, 3, go.
call me
Old Nov 12, 2012 | 08:33 PM
  #39
lowprofile's Avatar
E55
Next time for sure. Nice reaction time! What's the story with going into limp mode again? Are you running it in dyno mode?
Forgot to say congrats on the 1.57 from the previous night. NOICE!!!
Old Nov 12, 2012 | 09:37 PM
  #40
you to Hate
Thanks alot man! Yes the car is in dyno mode. The 2 times it's gone into limp mode I've had real bad wheel hop/spin on the launch. I was going sideways when it went into limp mode this time.
Old Nov 12, 2012 | 10:17 PM
  #41
Hammer Down's Avatar
2015 E63S, 2018 E63S
Big Easy, why do you switch to dyno mode?
Old Nov 12, 2012 | 10:55 PM
  #42
you to Hate
All my best times were done in dyno mode. Since I've started modding the car, I've launch it so many different ways. I find that this works best for me. I keep breaking sh*t if I launch it any other way.
Old Nov 12, 2012 | 11:12 PM
  #43
Hmm interesting I've never tried dyno mode, I wonder if I need to try that in order to hit 1.6 or better
Old Nov 13, 2012 | 11:39 AM
  #44
lowprofile's Avatar
E55
Not to step on E's toes, but dyno mode is not a requirement, just an option. Perhaps the better times are a result of a better burnout in dyno mode? It seems that each model year reacts differently to the given tune on that car. I had one tune on my car which made it difficult to spin even the street tires without the throttle cutting back. Fwiw, none of the track passes on my car were made in dyno mode, and it has never gone into limp mode either. The bottom line is to just figure out what works best for you and your ride.
E, I'll be tuned in to read about your new PB this weekend. Good Luck!
Old Nov 13, 2012 | 12:04 PM
  #45
Dirt Scooters
I've had the occasional limp mode problem in dyno mode as well as sport mode. I've made passes in and out of dyno mode with about the same results. These cars are just so weird it seems.
Old Nov 13, 2012 | 12:35 PM
  #46
you to Hate
Yes every car is different. You have to figure out what works best for you.
Thanks, I'll keep you posted.
Old Nov 14, 2012 | 07:38 AM
  #47
urbamworm's Avatar
How do you make a pass NOT in dyno mode with drag radials/slicks? Do you do a burnout in dyno mode then turn car off and take out of dyno mode? Or do you just do a small burnout powerbraking it for that 1 second it lets you then let off brake doing a rolling burnout up to the line and just say that is good enough?
Old Nov 14, 2012 | 08:30 AM
  #48
Dirt Scooters
My car would let me doing burnouts without being in dyno mode and i'm talking about 2nd gear rolling 1/8th mile burnouts without the computer going crazy.
Old Nov 14, 2012 | 08:39 AM
  #49
urbamworm's Avatar
That is crazy, what year is yours? This is what I would do with my 05. Power brake then have to let off brake and start rolling when I feel it start to cut power, keep foot planted, then it will stay blazing until I let off to stop at the line.
Old Nov 14, 2012 | 08:48 AM
  #50
chawkins2001's Avatar
2006 E55 AMG
I absolutely cannot burnout without dyno mode while power braking. The only thing it will do is rolling burnouts, even then, it cuts power some.
