leak at the rear fuel rail
2006 E55 AMG
been smelling gas the past few days in the engine bay, Looked this morning a found a leak at the back of the fruel rail under the trottle body, Is this a hard fix and anyone know of a DIY Do you cut the clamps from the airbox and just use hose clamps. Not sure is it is just simpler going to the Indy. It isnt pouring out but coation the intake tube and stinking to high hell. I appreciate any help Thanks guys!
2006 E55 AMG
2006 E55 AMG
Update, gas was coming down the fluid check tube behind the valve body. Still can't see where it is coming from. Making me nuts. Is it common the have the throttle body leak?
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
If you have some other mods for power it may be time to upgrade to an aftermarket setup. Or maybe get a stock take off from someone that upgraded theirs.
Just to add. The dampner is located on the fuel rail near the trans tube. It is circular.
2006 E55 AMG
Fuel does not pass through the throttle body, so no, that is not leaking. The fluid check tube you mention, are you talking about the transmission tube with the red cap? If so, it sounds like the fuel pressure dampner is leaking. It is held in place by a large spring clip. Not too difficult to replace.
