82mm TB - A year of problems!
ODB2 = P0106
STAR = B28 Pressure Sensor - Signal Implausible (or something like that)
Typically it happens on light/med acceleration between 70-85 mph or if crusing for more than 50 mile journeys.
Orignally fitted a EC kit which I think is a non MB TB (has no vent at rear) changed this to a MB part but still the same code!
I have decided to give it one more go and will remove but will refit myself and use all new gaskets and assembling with care.
So how can you help well first what gaskests are needed? have found this from other threads
Gaskets
A273-141-06-80 (Throttle Body)
A113-141-07-80 (Plenum to SC)
A113-098-00-80 (Right Intake)
A113-098-01-80 (Left Intake)
A113 141 09 80 (x2) These are the gaskets which go between the s/c and head.
Is this all of them or are there more needed, I dont need the Y-pipe o ring as I have a Needswings CAI.
Any tips on order or particular things to look out for would be appreciated.
You might have a leak somewhere from taking the blower off but heck your tps and get back to us.With star you can also adjust your TB for park and drive %
610 rpm and 1% in Drive and 730 rpm and 1% in Park, I am presuming that 1% means more than 1% but less than 2%. Will check with ScanXL which should give me more accurate data.
Park - average is 730 rpm with 1.6% TPS
Drive - average is 610 rpm with 1.6 % TPS
Does this sound right?
Check your oil vapor hoses that go under the tb and make sure everything is tight.also what tb do you have? a true MB one or an audi?
I gave up on the 82mm audi/gt3 ones and went with a 80mm amg one and made sure everything was snug.
Check your tb to see on what side the hole is for the vapor hoses also,you want the hole to be behind the blade where there is a lot of vacuum .
I am pretty much at the stage where I give it one more go with a complete refit or swap to an 80mm
82 is way more of a hassle and does comes with drive ability issues every now and then. Not mentioning the fact to revert back is also a head ache if u started to cut away at teh 80mm Ypipe and airbox etc
GL
I hope it's the rubber gasket that sits on the bypass throttle body as after checking the invoice it's not listed so the garage would have reused the old one, I might also just bite the bullet and get the Weistec kit.
