Quaife LSD Questions
I have thought to buy an LSD Diff.
But i do have some question.
Does the ESP work as normal ?
I mean for example (a car without LSD): The road is slippy and the cars end go sideways. The esp/abs brake up for example the left rear tire. And the car is going straight again.
On a car with LSD. If the same thing happens, when the esp goes in to brake the left rear tire, the right gona slow down as much as the left right ?
In that case the ESP will not work as before ? AND Getting confused ?
Or is it like i have understand lsd only lock the both tires when the power comes from the engine. Not backwards ?
Do some have the instructions to change the diff ? torgue ??
Do i have to take out the hole rear axle to do that ?
Or can i install the quaife with the rear axle on ?
Thanskful for answer sorry for my bad english
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
I would strongly recommend that you have a Mercedes Benz service facility or a experienced technician do the work. Also replace the bearings at the same time.
