2003 e500
Old Dec 2, 2012 | 03:01 PM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
2003 e500
Need help I have a 03 e500 that has a faulty SBC reservoir.
Dealer want 900
Is there a way I can buy the past and replace it myself?
Thank you
Old Dec 2, 2012 | 03:16 PM
GT-ER's Avatar
2005 E55 AMG
Buying the part is not the problem, it costs about $350 new. You need a scanner capable of relieving the SBC brake fluid pressure to swap the part out ( 45 minute job ).
Old Dec 2, 2012 | 03:22 PM
Manuyc's Avatar
Can I just disconnect the battery and the sbc connector to swap it out and open the bleeder valve on the calipers to releave the pressure.
I have a bleeder system if I need to bread the brakes
Old Dec 2, 2012 | 03:42 PM
GT-ER's Avatar
2005 E55 AMG
Won't work as the calipers aren't under pressure when off but the reservoir IS under pressure at all time.
Old Dec 2, 2012 | 04:17 PM
GT-ER's Avatar
2005 E55 AMG
Buy an autoenginuity scanner with the mercedes extension. Between the scanner and the part it should be cheaper than what the dealer is charging and you and you have a very valuable tool to keep.
Old Dec 2, 2012 | 05:30 PM
Manuyc's Avatar
Where would I be able to get that autoenginuity from?
Old Dec 2, 2012 | 05:33 PM
Manuyc's Avatar
http://www.autoenginuity.com/products-scantoolpc.html. Is this website you went to?
I have this one at home will this scanner work?
Old Dec 2, 2012 | 06:09 PM
berti_00's Avatar
2016 Cls63s AMG
Aight.
Old Dec 2, 2012 | 06:35 PM
Manuyc's Avatar
Originally Posted by berti_00
Aight.
Sup brah long time o see
Old Dec 2, 2012 | 06:38 PM
berti_00's Avatar
2016 Cls63s AMG
How was your guyses dinner?? I wanted some sushi
Old Dec 2, 2012 | 06:48 PM
Manuyc's Avatar
It was good man the sushi was banging brah man
Manuyc's Avatar
Aight.
You need to change the 500 hp to 500 whp
Old Dec 2, 2012 | 07:21 PM
GT-ER's Avatar
2005 E55 AMG
As far as I know the autoenginuity scanner is the only "cheap" scanner that can do it.
I bought it from that same site.
Old Dec 2, 2012 | 07:26 PM
Manuyc's Avatar
Awesome thank you GT-ER I will order it. And your right you do need one of these scanners at home for a merc, because the scanner I have is mostly for american cars.
Plus the scanner you told me to get pretty much pays for itself that I would have got a tech to use only once
Old Dec 2, 2012 | 07:47 PM
GT-ER's Avatar
2005 E55 AMG
No problem. :-)
