Transmission issues
Then, it started banging gears hard and acting weird.. Then started slipping pretty bad and even went into neutral once. (this all started happening after I bottomed out on a speed bump the day before and after that it started whining louder and louder until this started happening.)
Took it to a friends shop, changed the filter and he changed the fluid (i'm pretty sure it was low).. He used junk fluid (which is why I will be doing a flush soon)
So, after he did that.. the trans stopped slipping (even though I think it is still a bit low) but still doesn't seem to be able to make up it's mind at times on which gear it wants and it also shifts really rough.
I will be doing a full flush of fluid and changing the ground plate.. My question is, is there anything else that could be giving me issues that I should replace while I am doing all of this already?
I read something about solenoid valves on the valve body?...hmmm.. Just want to get it all squared away at once.
Please help
thank you guys in advance, i appreciate it.
My friend had kinda similar issue (trans not shifting, banging etc..) he had to replace the conductor plate on his car (big $$$).
Even if it doesnt leak on the ground I would still replace it as thwy can leak inside andfluid can end up being pumped through the harness into the tcm.
Replace that plus fluid and report back.
This is just a shot in the dark, but I thought I would throw it out there. Good luck
