Storage or Winter storage..
2005 e55 amg w/mods, 2015 GMC diesel,2016 X5 Msport
So as it seems since I bought the car I dont get to drive it much and often times it sits for atleast 5 days and now that it is cold I get concerned about tire flat spots ? Any solutions???
Also, recently the mirrors stopped working if I manually try to press the switch but still works for the memory switches and what have you. Any thoughts there?
PLATINUM SPONSOR
Lift car on jack stands to remove the weigth off the tires.
Try cycling the mirrors again, if no luck here, you will have to go to dealer, indy or buy ands intall the mirror parts.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
What do you mean "cycle the mirrors"?
Jack stands are not really an option as that is gonna be really inconvenient when I wanna actually drive it or get a chance too.
