pros and cons to locking up an E55 supercharger clutch
Old Jan 8, 2013 | 10:55 AM
groove66's Avatar
2005 e55
Originally Posted by skratch77
before you guys melt your motors spinning the blower all the time think of this,our ecus basically are NA and Bossted ecus,we run very high timing when the blower is off and once on load the ecu pulls timing big time and dumps a **** load of fuel.
now lets say you are crusing at 40mph in 4th gear with 4 people in the car and you have your blower making full boost and you give the car 10% throttle,guess what? you just ran 35D timing with almost zero fuel and put massive load on your engine with max boost!!!
do NOT run the blower all the time without a proper off boost tune
this is a simple Speed density system. it runs off the map sensor if the map sensor is seeing full boost and you tip in throttle it should already be on the boost side of timing.
Old Jan 8, 2013 | 10:57 AM
Forrest Gump 9's Avatar
shrimp boat
Every boosted car is "NA and boosted"
When you cruising the by-pass valve would open like normal. When you get on it the by-pass valve would shut and boost would be build, again just like a normal operation.
Eleminate the clutch would only affect fuel economy and the longevity of the sc a bit. This is not trying to re-invent the wheel, it's meerly re-engineering what Weistec had done. Like I said, if Weistec want to be nice they CAN tune the car without the clutch no problem.
Old Jan 8, 2013 | 10:59 AM
Gadget's Avatar
06 E55 AMG, 13 C63 AMG
I guess I need to draw a picture or something.
The manifold pressure is controlled by the throttle. If the supercharger is spinning or not spinning the throttle still controls the manifold pressure. If the throttle is less than roughly 30% open the manifold will be in vacuum whether the supercharger is spinning or not.
There will not be boost in the manifold if the throttle is not open enough. It cannot grab air to compress. It is just that simple.
Old Jan 8, 2013 | 11:02 AM
skratch77's Avatar
2005 E55
Im talking about light load situations in high gear and say 5-10% throttle Im sure weistec tuned the na part of the tune with there blower on all the time.
Old Jan 8, 2013 | 11:08 AM
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
Originally Posted by Gadget@URD
Boost is still controlled by the throttle.
Just because you have the rotors spinning does not mean you are making boost.
G
^This is true^
My N/A SL500 has a clutch less blower on it. At a 40mph cruise she's at around -15lbs of vacuum. The rotors are definitely spinning, but there's no boost.
Old Jan 8, 2013 | 01:27 PM
99lightning's Avatar
99 ford lightning
I would imagine calculated load based on tp is what changes the fuel and timing parts of the tune so a direct drive wouldnt really be a issue as long as you can figure the bypass in the tune.
Old Oct 3, 2018 | 04:11 PM
  #32
TraumaDude's Avatar
2019 S63, 2006 CLS 55, 2005 Infiniti QX56, 1994 Softail Springer
I know this is a very old thread, but can you tell me where the bypass valve is located on a 55 engine? I have a mechanic telling me there is no such thing.
Old Oct 3, 2018 | 07:10 PM
  #33
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Take it to someone who understands the engine. It's just forward of the TB and under. The plugs are interchangeable, but DON"T mix them up.
Old Oct 3, 2018 | 09:10 PM
  #34
trabots's Avatar
2006 E55, 2006 SL55, 2006 LS7 Ute
I have only a 83mm fixed pulley and a Race IQ tune. Massive increase in seat of pants pull confirmed by a 4.5 sec 100-160kph pull compared to 5.2 sec stock. Times by V-box. My stock pulley broke and damaged my hoses etc. with only 100k km on the car. Throttle response is better.
