help please
Old Jan 15, 2013 | 11:19 AM
MADMIKE's Avatar
w211 E55
help please
if i run a 245/30/20 and 275/30/20 will i get a abs or esp light?
rims a x9 an x10.5
thanks
Old Jan 15, 2013 | 11:23 AM
E55Dimon's Avatar
E63S
No, but you should really run 285 /25 in the back.
Old Jan 15, 2013 | 02:05 PM
e50zero's Avatar
E500
285/25 is nice but not much rubber there.
Old Jan 15, 2013 | 02:11 PM
E55Dimon's Avatar
E63S
/30 looks suv status in the back and rubs if lowered. Ive had 285/25/20 in the back before without issue. I have 295/30/19 on now for winter and rub with rolled fenders.
Old Jan 15, 2013 | 07:35 PM
MADMIKE's Avatar
w211 E55
thanks
Old Jan 16, 2013 | 12:47 AM
desired_speeds's Avatar
2007 SL55 AMG
I had that tire set up before. It was fine, I actually liked the extra cushioning in the rear but it made the rear end sit a little high.
Old Jan 16, 2013 | 01:08 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Here's mine on 255/35/20 and 295/30/20 , no rubbing.
I know some prefer a lower profile and lower ride height. I used to like that also but now fancy a little more sidewall and less worries about bumps and road debris. This is a driver, were it a showcar I'd do the slammed on slims look.
Old Jan 16, 2013 | 10:36 AM
E55Dimon's Avatar
E63S
Thats the best looking /30 rear sidewall I have seen on an E55. What're you lowered on and fenders rolled/pulled?
Old Jan 16, 2013 | 02:05 PM
Thanks!( I love the white w E63 front btw)It's lowered with STAR and no quarter panel/ wheelhouse modifications. Its not really lowered that much, the gap is taken up by the tire so it looks low. I have very little clearance concerns when navigating the jacked up streets around here, even with the CF lip on the front hanging down.
The wheels are 20x10 ET39.
I'm going to do a built engine/Weistec blower combo this spring and either put it in this car or an SL. If I do this car Im going to do some wheelhouse surgery and fit 20x11s with 315/30/20 on the back for traction. Can't wait!
