Removing trunk lining - cargo tie downs?
BMW M5, Jeep SRT8, MB E63
I was removing the trunk lining to access the tail lights and feel like I'm missing something. The 2 cargo tie down rings at the front and back bottom of the side liners - I never see these mentioned when people are accessing the tail lights, but I could not get the liner over them. Is there a trick to getting the liner over them, or do I need to go get a star bit and remove them? None of the torx bits I have were a perfect fit.
Pic-
Thanks!
Pic-
Thanks!
They will need to be removed. Those hold the cargo liner in place, as well as I believe 2 or 3 fasteners. Then it will shimmy out, don't forget the ring around the arm on the trunk lid, it breaks easily if you don't remove it properly.
Thanks, off to the hardware store.
