Common M113k engine and transmission problems?
I am interested in acquiring an 55k powered Merc and I would like to know what common problems these engines have and how to resolve these.
1. I read that early models have a problem with the heat exchanger which resulted in coolant leaking into the transmission oil.
Which model years are affected? I assume this can result in an transmission failure?
Is the transmission reliable otherwise if no coolant is leaking into it?
Adding an external transmission oil cooler should help fixing the problem and the old watercooler can be retained?
I also read about transmission flushes. I assume these are necessary if coolant is in the transmission? Does such a flush get rid of all the coolant?
2. Furthermore what is the issue with the IC pumps? Do you suggest replacing them for aftermarket units?
I read that 2006 models received an upgraded pump?
Do you also recommend using an additional or a larger IC heat exchanger and even an IC tank?
3. I also read that the #8 cylinder is being affected by starvation which results in explosion.
Adding a loop to the fuel rail should help getting rid of the problem?
4. Some model years are supposed to have one, other two oil coolers. Which model years do have two oil coolers and do you recommend adding another one on early models?
5. Is there a problem with SC belt slipping which needs to be taken care of?
6. At what mileage does the supercharger usually needs to be rebuild?
7. Are there any other M 113 E 55 ML (the engine we are talking about here) specific problems I am not aware of like head gaskets, timing chain, oil or water pump or other things?
8. Are there any other engine related changes throughout different model years?
Thanks for all your help!! =)
Stay away from the 03's
Is the transmission reliable otherwise if no coolant is leaking into it? Yes
Adding an external transmission oil cooler should help fixing the problem and the old watercooler can be retained? Defeats the purpose if you are still going to use the radiator to cool the trans fluid
I also read about transmission flushes. I assume these are necessary if coolant is in the transmission? Does such a flush get rid of all the coolant? Yes
Furthermore what is the issue with the IC pumps? Do you suggest replacing them for aftermarket units? They go weak over time and eventually fail. Bosch pump with the part number ending in 010
I read that 2006 models received an upgraded pump? Yes
Do you also recommend using an additional or a larger IC heat exchanger and even an IC tank? Yes
I also read that the #8 cylinder is being affected by starvation which results in explosion. Yes
Adding a loop to the fuel rail should help getting rid of the problem? Yes it helps
Is there a problem with SC belt slipping which needs to be taken care of? All belts slip the slippages becomes more when you get a larger crank pulley
At what mileage does the supercharger usually needs to be rebuild? Only if it fails
Since the car sat, you might want to consider changing the diff oil, Trans fluid, and flushing the brake fluid.
actually once i bought the car 3 weeks ago i did the following:
change engine oil+filter+gaskets, change brake fluid, change cooling fluid, change air filter+a/c filter, changed cranck sensor, new tran oil+filter+some electronic unit in it, new diff oil, checked spark plugs (were ok), checked belts (good condition).
i think it should cover the "regular maintainance" part.
regarding the bearing you mention, i noticed when im starting acceleration (modorate, not pedal to the floor) theres for like half a second some squealing and than its gone (only on slow speed like 10-15 km/h when accelerating).
could it be related to what you wrote?
my first guess was maybe one of the engine pulleys need a replacement.
cheers!
