Weistec Blower: Customer Review
Old Feb 12, 2013 | 11:02 AM
  #51
ajm55's Avatar
2006 E55 AMG
Originally Posted by whipplem104
This is the 1st time anyone has posted IAT values and honestly they seem a little high. This is totally performance related. You stated around 158F max iat on the dyno and then changed some stuff and said at cruise you were around 70-100F above ambient. If I am reading this correctly there was something wrong with the intercooler setup. I see those temps if I have my heat exchanger out of the loop after full heat soak. That is why I ask how hot it was outside and what were peak iat on the pulls on the road? Was it around 70-80 outside? Did it get over 200F iat?
IATs were a problem from the time we installed the blower. However, we also installed the trunk tank and split the system at the same time. Some mistakes were made here. They were corrected and ultimately the flow through the split system was very strong. This notwithstanding, we continued to experience IAT issues up until the time I popped the motor. I can't say whether or not the IAT issues had anything to do with the blower. I'll post all the relevant data in an engine failure thread soon with a view to eliciting the views of the many experts (as also the many wanna-be experts) on the forum.
Originally Posted by Denroll
Have the heads been pulled yet? What's the Battle Damage Report?
The heads have been pulled. To the naked eye, they look okay. There's a fair amount of black residue on one which we are hoping is of no consequence and can simply be cleaned up. Both have been sent to an engineering shop for inspection. The battle damage report is yet to be finalised (he remarks nervously).
Old Feb 12, 2013 | 01:29 PM
  #52
whipplem104's Avatar
1990 300ce supercharged and intercooled
So the reason I ask is that besides being able to make more boost the entire point of a larger supercharger is to make more boost at lower outlet temperatures. So given that I think that something was not working right.
Old Feb 12, 2013 | 03:11 PM
  #53
kustom2k1's Avatar
03SL55
Try running water through the Weistec IC . There could be an obstruction in the IC.
Old Feb 12, 2013 | 04:13 PM
  #54
ajm55's Avatar
2006 E55 AMG
As part of the bleeding process, my installer ran water into the s/c water inlet port until it exited the out port without any air bubbles. Now there's a good volume of oil in the s/c that got sucked in when the engine failed. The unit is going to be shipped to Weistec so they can clean it out and pressure test it etc. To their credit, they have agreed to meet me in relation to the costs associated with this exercise.
Old Feb 12, 2013 | 04:16 PM
  #55
Max.H's Avatar
E55
Originally Posted by Prada
Lol! How about we race for it?
Against a proven mid 10 sec car?
Old Feb 12, 2013 | 04:31 PM
  #56
ajm55's Avatar
2006 E55 AMG
We made some mistakes with the cooling.
Initially we plumbed the system as follows: trunk tank - h/e - I/cooler - Bosch pump. On Weistec's recommendation the system was re-plumbed to accord with their installation instructions.
Secondly, the piping beneath the chassis was initially 12 mm inside diameter piping. On Weistec's advice, we replaced this with wider piping (I think 16mm inside diameter and 19mm outer diameter).
The IAT sensor was checked as part of an elimination process. It was functioning correctly.
Weistec did ask us to install the bigger upper pulley which I had bought with their kit as an extra.
We didn't do this. Our reasoning was that once the plumbing issues were addressed, it became clear that the IAT problem was less boost related than it was non-boost related. As set out in the OP, under boost, the increment in IATs was slightly lower on the Weistec unit than on the stock s/c - presumably as a result of the bigger, more efficient intercooler. That being so, our focus was on determining why at idle and with casual driving, the IATs would climb so quickly to uncomfortable levels.
We were also asked to re-run the car on the dyno but with ice in the trunk tank. We did not do so. We should have.
Old Feb 12, 2013 | 07:59 PM
  #57
Thericker's Avatar
V12-Biturbo
I don't understand Weistec's rationale here using the trunk tank full of ice? It ONLY gives temporary hp/tq increase making the car read far far below ambient temps UNTIL the ice is gone about 5 min later (from my own exp you can see as much as 35-40 rwhp on V12 TT's) IE Wesistecs 570+ rwhp results w/Trunk tank of ice are most likey TRUE but after the ice is gone so is the 30+ odd rwhp gain (I don't know exact amount of hp/tq gained on 55k platform but I do know it's substantial, OBVIOUSLY worth the massive headache for Weistec to fab/install ice-tank)
INMYOP def added to fluf dyno #'s to sell more kits, why else would they add it to their test car to make 570 rwp or tell you to re-run it on dyno w/ICE to achieve advertised #'s
So what would Weistec's rwhp be w/OUT ICE? 570 rwp minus 30-40 rwp = 530-540 rwp hmmm
Old Feb 12, 2013 | 08:06 PM
  #58
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
I'm not Weistec but I think I've concluded from their other posts that the reason they wanted ice in the tank was to see if it melted after a pull or two. This would indicate that the fluid was indeed pulling heat from the blowers discharge like its supposed to. A few pulls with no change in the temp levels of the tank might indicate air trapped in the system or fluid moving either too fast or too slow to transfer heat efficiently.
  #59
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Their reasoning had nothing to do with increasing HP(albeit would do that), it was to verify the efficacy of the intercooler. They hoped that if the ice didn't melt away quickly then that would show that there might be air in the system somewhere stopping the flow. Of course if the opposite happened then we would know the system was flowing water just fine.
Old Feb 12, 2013 | 08:07 PM
  #60
PACougar's Avatar
Damn you for beating me to the punch
Old Feb 12, 2013 | 08:18 PM
  #61
bob n weave.. I be bobbn n weavin
Old Feb 12, 2013 | 08:25 PM
  #62
Thericker's Avatar
V12-Biturbo
Ahh understood But it's still raises hp/tq nicely albeit temporarily...
Old Feb 12, 2013 | 08:33 PM
  #63
PACougar's Avatar
I totally agree, but I haven't seen where they've said you need the ice in the tank to achieve their claimed HP/TQ numbers. Now I could have totally missed that somewhere.
Old Feb 12, 2013 | 09:20 PM
  #64
Thericker's Avatar
V12-Biturbo
IDK maybe I misunderstood that from Weistec requesting the member in this thread to re-run dyno w/ice, since you elaborated on reasoning behind ice tank etc..
Still I'd love to see this Q answered
Old Feb 12, 2013 | 11:26 PM
  #65
I was curious on this too so I went and stalked their announcement thread
How high can we safely run the boost and was the last run with ice tank? Thanks for the update.
None of the runs were with ice and all runs were done on 91 octane fuel. We recommend running 17psi on pump gas. Thank you!
Weistec Engineering
Old Feb 13, 2013 | 12:48 AM
  #66
Thericker's Avatar
V12-Biturbo
Weistec Engineering
Interesting.. But since everyone here inc Weistec wants to see these E55k's break 600 rwhp w/big blower, why wouldn't they try adding ICE on their final Dyno runs since it's proven hp/tq recipe & already listed/installed on the car. (They could easily say final dyno w/ICE vs NO ICE)
If they topped out @ 570 rwp w/out then 600 odd rwp easily in grasp Sorry I'm not buying they didn't run ice on dynos for 1 second..
Thnx for checking old info though
Old Feb 13, 2013 | 01:39 AM
  #67
johnnyblaze's Avatar
CLS63S
His car is currently not running. Thats the joke of the whole post.
Old Feb 13, 2013 | 03:20 AM
  #68
ajm55's Avatar
2006 E55 AMG
Precisely this ^^^^^. Some inexperience this side played a role. I think it very unlikely that there was air in the system. However, doing what was suggested would at least have eliminated this as a possibility. Hence my comment that we should have done so.
