sag
I have a 2005 E55 that I puchased then parked it for 5 months. Taking the cover off this am I noticed that it is sitting very low.
Is it normal to loose air in the suspension after its been sitting?
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
