Newest steering wheel in W211 ?
Rating: Thread Rating: 2 votes, 5.00 average.
Old Feb 16, 2013 | 09:27 PM
schnell!'s Avatar
'04 E55 AMG, '03 ML500, ‘13 BMW 528i
I think that I've read through all of the steering wheel threads... and haven't found what I'm looking for. What is the most recent steering wheel that anyone has retrofit into an E55? I absolutely love the wheel in our '13 E350 and now must have one in the older car as well. I realize that there would be some wiring issues with the shift paddles and that all of the buttons may not work. Any thoughts?
Thanks.
this --->
Old Feb 16, 2013 | 10:21 PM
GT-ER's Avatar
2005 E55 AMG
If I'm not mistaken DTC ( or something like that ) said the shaft was different and that it would not fit at all.
Old Feb 16, 2013 | 10:55 PM
Denroll's Avatar
'06 E55
I've got one from a CLK63 Black Series. I love it.
Old Feb 16, 2013 | 11:59 PM
grimm's Avatar
2005 E55, 2002 GT2
DCT Motorsports can make you a custom steering wheel. I ended up replacing my steering wheel with one of theirs--increasing the thickness (like the e60 M5 wheel), implementing the flat bottom, and later on retrofitted the E63 paddles (using the E55 switches--however I've been told there's a module someone sells that will allow you to use the E63 switches in the paddles)
In any case, I'd give them a call and see what they can do for you.
Old Feb 17, 2013 | 12:19 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
The "module" that you are referring to (Mercedes Paddle Converter module) which allows direct plug-in of the newer E63 aluminum paddles (into most AMG55 cars from 2003-2006 that came with shift buttons) IS available directly from DCT Motorsports. They can install it AND the E63 paddles in a stock wheel or a customized wheel for this application.
This module is also available in kit form (and includes paddle mounting hardware , installation templates, and instructions). This can be purchased from DCT motorsports as well or other retailers (or directly from me). Feel free to PM for additional information.
Chris
Old Feb 17, 2013 | 02:56 PM
kompressede's Avatar
Sold - 05' E55
Go for the DCT wheel. Check out their web site. I went for the e63 paddles also because I like the bigger paddles on the e350. I don't use them - they just look pretty cool.
Old Feb 17, 2013 | 08:55 PM
gazosnic's Avatar
e46 m3, w211 e55
There is a place in texas that will custom wrap your wheel and make it thicker as well for about $350.
Old Feb 18, 2013 | 06:33 PM
timeToy's Avatar
'08 E63 Wagon
According to MBenzNL, you can use a SL steering wheel (the one without button in the center of the button cluster on steering wheel). Obviously you'll also need the airbag.
Here is one in a W211:
SL wheel:
Old Feb 18, 2013 | 07:34 PM
schnell!'s Avatar
Thanks for the input, everyone. I'm aware of the wheels suggested, but was hoping that someone might have tried the late model one like I posted. Perhaps I'll have to be the guinea pig and see what happens...
Can anyone confirm that the steering shaft is/isn't compatible? If not, what year did it change?
Old Feb 18, 2013 | 10:31 PM
GT-ER's Avatar
2005 E55 AMG
SL wheel:
Woohoo...love it.
Old Feb 20, 2013 | 02:14 AM
Max.H's Avatar
E55
Im running the E63 steering wheel it was one of my best mods. I cant stand the thin antiquated E55 steering wheels and the ugly air bag.
Old Feb 20, 2013 | 05:11 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Yeah I really like the one in the middle with the CF on the bottom.
Originally Posted by GT-ER
Woohoo...love it.
Old Feb 20, 2013 | 07:59 AM
1badassbenz's Avatar
Mercedes
SL wheel:
What do you mean the one without button in the center of the button cluster on steering wheel?
Old Jul 6, 2013 | 10:40 PM
aghakauve's Avatar
GLC63s, W222 S63, W223 S580
BUMP... Any updates on this? Has anyone tried or successfully done this mod?
Old Jul 7, 2013 | 11:09 AM
berti_00's Avatar
2016 Cls63s AMG
that def looks sick
Old Jul 7, 2013 | 02:30 PM
Denroll's Avatar
'06 E55
This wheel works in our cars:
Old Jul 7, 2013 | 07:11 PM
gazosnic's Avatar
e46 m3, w211 e55
model year plays into the equation as well. Earlier years may need more than just airbag and wheel. Someone correct me if i am wrong, but '03-'04 may also need new clock spring and potentially something else.
Old Oct 7, 2014 | 02:10 PM
AAlfarah's Avatar
W211 E500 2003
Hi, I'm trying to replace my pre-facelifted steering wheel to the face lifted style (w219), every thing looks perfect no srs light, my only issue is that the buttons and the horn do not work, I think I need to by one more connector, the used air bag I bought only had one connecter that goes from the wheel sensor to the steering, were the preface lifted air bag had two connectors coming from the wheel sensor.
Old Oct 7, 2014 | 02:14 PM
berti_00's Avatar
2016 Cls63s AMG
Old Oct 7, 2014 | 02:54 PM
JoeNobody's Avatar
Mercedes
Do you have W211, or W219? If W211, then 2003-2004 will not work with the newer steering wheel unless you update the steering column electronics.
Old Oct 7, 2014 | 03:05 PM
AAlfarah's Avatar
W211 E500 2003
I have a w211 e500 2003, is it only the steering wheel sensor or there are other parts that needs to be swaped, I'm fitting a 2009 w211 steering wheel on it.
Old Oct 7, 2014 | 03:12 PM
JoeNobody's Avatar
Mercedes
The entire column of electronics needs to be changed, along with changing the harness the column connects to.
Old Oct 7, 2014 | 03:23 PM
saleen01's Avatar
2004 E55
What place, what city?
Old Oct 7, 2014 | 03:47 PM
JoeNobody's Avatar
Mercedes
Lightbulb
For 2003-2004 cars, to update the steering column to accept newer steering wheels:
You will need the steering column electronics, from any 2005-2009 W211.
This one would be perfect:
http://www.ebay.com/itm/MERCEDES-W21...Y/171470507708
You also need to replace the existing column harness with part 2114404509 (the old harness looks similar, but it will not fit).
When wiring up the harness, some of the existing wires need to be swapped as the wiring changed slightly.
On the new plug:
Pins 1 and 2 are steering wheel heating (they can be ignored if car is not equipt with it)
Pins 3-6 need to be color matched they are the airbag connectors.
Pins 8-13 stay exactly the same don't switch anything.
My notes from my install were:
Original harness pin -> airbag
4 -> yellow 2
3 -> yellow 1
1 -> green 1
2 -> green 2
New harness pin -> airbag
5 -> yellow 2
6 -> yellow 1
4 -> green 1
3 -> green 2
So pins 3-6 need to be matched up with the old wiring so they connect to the airbag correctly. Use a multi-meter and check continuity from the updated column connector pins, to find which pin is the correct airbag wire.
But do not take my notes as fact, and you should verify which wires to swap yourself(!!)
And finally after all of that, use DAS and disable the old paddle shifters under Drive -> Gear Selector Module -> Adjustments
The new shift paddles will work after this.
Credit goes to Mertd93, as he was the one to figure all this out.
Old Oct 7, 2014 | 05:19 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
mine 2010 SL63 steering wheel and bag
Newest steering wheel in W211 ?-2010sl63steeringwheelinaw211_zps40b196d2.jpg
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
