idle too high P0507 after cleaning throttle body and valve cover gaskets
Old Mar 4, 2013 | 11:39 PM
Hellzno's Avatar
E55 AMG
over the weekend I replaced my plugs, valve cover gaskets, and wiped the inside of my throttle body clean.
I started my car and noticed a high idle 1200-1400-rpm. I went for a test drive and immediately saw a check engine light. I went back home and scanned the car with my rev2 app iphone and saw P0507 idle too high code. I tried to clear but it would come back. Tried reset ECU trick...no luck. tried to reset throttle body....no luck. I was suspecting I needed STARS to relearn TPS on the throttle body because I moved the flap inside it. After searching and many people saying check hoses....I found nothing. I inspected the throttle body again tonight and BAM found it.
Metal line attached to drivers side valve cover closest to firewall. Follow this line towards throttle body. Connects to driver side of throttle body close to the surge tank. I had to remove my surge tank to reattach.
Oh I had to put a piece of carpet on engine to crawl up on this biatch to make love to her while inserting the "tube" I wanted to get a good view
:s mash:
Old Mar 5, 2013 | 12:43 AM
Lawrence1's Avatar
2011 G55 + others
Yeah that thing is a pain in the *** to put back in and always comes out when doing the valve cover gaskets on these cars.
Old Mar 5, 2013 | 02:21 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
I think just about everyone that has done a valve cover gasket has run into that exact same thing.
Old Mar 5, 2013 | 08:50 AM
TheOtherDodge's Avatar
2005 E55 AMG
Aaron, check for a vacuum leak. That will cause a high idle...
Old Mar 5, 2013 | 09:24 AM
berti_00's Avatar
2016 Cls63s AMG
yahhh i freaked out when mine was like that, and than i asked shardul here on the forum and told him whats going on. He immediately pointed me that hose and said its probably not in. So i go to look at and boom it wasn't. Put it back in and smooth as butter
Old May 5, 2018 | 09:45 AM
Austinsec's Avatar
Sl55 2003
Does someone have a picture of the hose and location
Old May 5, 2018 | 08:13 PM
ranger101's Avatar
E55 AMG
Removing the drivers side surge tank makes this job MUCH easier. One hose clamp and a few bolts and you’ll have it off.
Old May 9, 2018 | 12:13 AM
Austinsec's Avatar
Sl55 2003
Do you have a picture of the location Im lost and need to do inspection
Please help
Old May 9, 2018 | 02:56 PM
Austinsec's Avatar
Sl55 2003
little metal tube with rubber plug
Found it here is a picture.
Old Feb 26, 2023 | 02:06 PM
S_Holford's Avatar
2003 S55 AMG, 2005 C320 Coupe, 2020 Jeep Gladiator Mojave
Proof that searching the forum is your friend. I just changed all my hoses and valve cover gaskets, then got P0505 and P0507 codes. Sure enough it was that damned hose underneath the surge tank.
Old Feb 28, 2023 | 02:14 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Good that you found it, its quite hard to spot if you dont know exactly where to look. Once you've spotted it, you cannot unsee it again, so next time its easier.
Old Mar 2, 2023 | 03:25 PM
j-mo's Avatar
2006 E55 AMG, 2019 BMW M240I xdrive coupe, 1969 Mach 1 Mustang
Great, helpful post! Saving this one as I have to do my valve cover gaskets soon.
