thrust arms
Old Mar 10, 2013 | 03:51 PM
jawdoc's Avatar
2005 E55 AMG
thrust arms
Based on the excellent advice I got here, I purchased both front thrust arms for my 05 E55.
The bushings need to be pressed into the arms. Is this done with a vice? or do I need to take it somewhere to get them pressed fit?
Old Mar 10, 2013 | 11:12 PM
GT-ER's Avatar
2005 E55 AMG
If you purchased new arms then they will bring the bushings already installed.
Old Mar 10, 2013 | 11:48 PM
E55AMGGG04's Avatar
04 w211 E55
I purchased new arms from the dealer and it did NOT come with the bushings. I bought the arms and bushings separately and had them pressed in by my mechanic. $160 just for labor.
Old Mar 11, 2013 | 06:16 AM
GT-ER's Avatar
2005 E55 AMG
Oh, well, now that I think about it mine weren't oem.
Old Mar 11, 2013 | 07:04 AM
jawdoc's Avatar
2005 E55 AMG
ok - sounds like a professional should do it then.
Old Mar 11, 2013 | 07:09 AM
cwmateiuc's Avatar
2006 E55 AMG
$160 to press two bushing in sounds like a lot.. You can go to Harbor Freight and buy your own press for something close to that price lol
Old Mar 11, 2013 | 08:31 AM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Old Mar 11, 2013 | 08:55 AM
novae500's Avatar
W211
What made you get new thrust arms??? Creaking noise? Vibration? I had creaking in my ds front area going over speed bumps and low speed can hear it . Sprayed some wd40 around the joints bushings and now more creaks. But think I need new wheel bearing did the pull test and slight movement click. .
Old Mar 11, 2013 | 02:16 PM
E55AMGGG04's Avatar
04 w211 E55
I guess I didnt make it clear. $160 to press the bushings and install the arms altogether.
Old Mar 11, 2013 | 05:21 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Did it sharpen up your steering any? I think my front steering input is a little numb, but that prolly has something to do with the Goodyear F1's which I don't care for much. Anyone else got some input on bushings or tie rod end wear/replacement?
Old Mar 11, 2013 | 08:03 PM
jawdoc's Avatar
2005 E55 AMG
I noticed that when braking, the right front would grab last. This was with a clunking noise which was reproducible at traffic lights by letting my foot off the brake slightly and back on.
I asked the advice of the members here and they suggested thrust arms. I took it to a dealer for service and they suggested both arms be done.
By the way....does a fuel filter really cost $800?
Old Mar 11, 2013 | 11:05 PM
zkeller's Avatar
04 E55
Filter is part of the pick up assembly in the tank. All comes as one unit. I think that even includes the fuel pump?
Old Mar 12, 2013 | 08:59 AM
jawdoc's Avatar
2005 E55 AMG
I hope it includes the pump at that price.....
by the way, can we go easy on the **** pics on this site? Im no prude but this site is for benz and **** sites are for ****. just my thought
Old Mar 12, 2013 | 09:54 AM
novae500's Avatar
W211
What **** pics??? Don't see any on this forum
Old Mar 13, 2013 | 08:20 PM
jawdoc's Avatar
2005 E55 AMG
can it be as easy as getting a $70 shop press at Harbor Freight and pressing those bushings in place?
Old Mar 13, 2013 | 08:46 PM
novae500's Avatar
W211
DIY in the other w211 forum. Need ball joint separator and ball joint installer tool too to do the job.
Old Mar 14, 2013 | 10:27 AM
jawdoc's Avatar
2005 E55 AMG
I couldnt find the thread on DIY for thrust arms...do you know where it is?
Old Apr 1, 2013 | 01:54 PM
jawdoc's Avatar
2005 E55 AMG
are those mercedes-specific tools?
Old Apr 1, 2013 | 02:24 PM
novae500's Avatar
W211
I got them off eBay. Search using w211 and will come up for both tools required to remove ball joints.
Old Apr 1, 2013 | 10:59 PM
lowprofile's Avatar
E55
I used the HF universal ball joint press. It is bulkier, but got the job done. I did need to remove the speed sensor (held in by one 10mm bolt) to make enough room for the tool sit flush.
Old May 11, 2013 | 06:06 PM
jawdoc's Avatar
2005 E55 AMG
do you know what size star socket is needed?
Old May 13, 2013 | 05:29 PM
lowprofile's Avatar
E55
Don't quote me on this because I did this about a year ago, iirc it was size 14 E-torx.
Old May 18, 2013 | 12:30 PM
jawdoc's Avatar
2005 E55 AMG
anyone know what the torque specs are one the nuts that secure the thrust arms?
Old May 18, 2013 | 12:54 PM
Toadster's Avatar
2005 E55 AMG
just had mine done a few weeks back - seriously tightened up steering, I was (and still am) impressed!
Old May 31, 2013 | 08:16 PM
jawdoc's Avatar
2005 E55 AMG
TRemendous difference. Steering and braking is much tighter.
I was getting a shake in the wheel upon braking like the rotor is warped. Now that is gone as well.
Took an hour once I had the right tools ...size 18 torx socket and size 21 wrench.
