water pump went bad, please advise
Old Mar 17, 2013 | 07:31 PM
pwrtrip99's Avatar
2004 E55 AMG
Hi,
I've had my E55 AMG (2004) for about 6 months, and really enjoy it. However, my water pump bearing went bad last week. I ordered an aftermarket replacement (GMB 147-2220) but it doesn't seem to fit entirely. The new pump is missing an extended flange with a hole that the idler pulley bolt would go through (the OEM one has this). Are there any non-oem pumps with that stupid little flange? Is it entirely necessary? I thought perhaps finding a spacer to replace said flange, but I have no idea if that's feasible or even a good idea.
Old Mar 17, 2013 | 07:50 PM
Shifter's Avatar
E55, SL63, ML550
why not just get a OEM one?
Old Mar 17, 2013 | 08:30 PM
E55Greasemonkey's Avatar
This place is a joke.
Use an OEM water pump..they have a very low failure rate and are direct fit.
Old Mar 17, 2013 | 10:36 PM
pwrtrip99's Avatar
2004 E55 AMG
The OEM is like $600, and the non-OEM is 75 or so. I'd like to try and avoid that expense, if at all possible. Has no one replaced their water pump without going OEM? BTW, I have around 130,000 miles on my car.
Old Mar 17, 2013 | 11:20 PM
sokarempire's Avatar
2003 E55 AMG Silver with Merlot Interior
I paid $288 from Mercedes Benz North (Houston) for an OEM WP about a year ago. Call around - $600 sounds steep
Old Mar 17, 2013 | 11:37 PM
about $484 online for the OEM pump...
Old Mar 17, 2013 | 11:52 PM
pwrtrip99's Avatar
2004 E55 AMG
I just wish there was an alternative, I suppose, but it appears I'm stuck paying an extra 190-440 for a tiny little flange. What's truly unfortunate is that the GMB pump fits perfectly otherwise.
Old Mar 18, 2013 | 12:25 AM
Toadster's Avatar
2005 E55 AMG
$434.40 - Parts.com
$130 rockauto.com
Old Mar 18, 2013 | 12:33 AM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
+1 for Rockauto. I got my plug wires from them. They were exactly the same as the Mercedes ones, even the same exact Bosch part number stamped, the only difference being they didn't have the Mercedes logo stamped on. They were like 1/3 the price of Mercedes ones if I remember
Not sure about water pumps.
Originally Posted by Toadster
Old Mar 18, 2013 | 08:17 AM
pwrtrip99's Avatar
2004 E55 AMG
Well the thing is, I bought the same part Rock Auto offers (GMB 147-2220). Every single vendor lists that part as being compatible. Maybe that extra flange isn't vital. All it does is essentially act as a spacer between the idler pulley and the block.
Old Mar 18, 2013 | 08:55 AM
Forrest Gump 9's Avatar
shrimp boat
Can you take some pictures of the differences?
Old Mar 18, 2013 | 09:06 AM
pwrtrip99's Avatar
2004 E55 AMG
I can try this evening when I get home.
Old Mar 18, 2013 | 10:27 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Used pumps are all over the place as another option.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Mar 18, 2013 | 01:02 PM
pwrtrip99's Avatar
2004 E55 AMG
Like on EBay?
Old Mar 18, 2013 | 03:23 PM
vntgspd's Avatar
Porsche 911
$282 (plus core charge) here:
http://www.pelicanparts.com/catalog/..._pg1.htm#item0
Old Mar 18, 2013 | 03:39 PM
pwrtrip99's Avatar
2004 E55 AMG
You're a life saver. Thank you so much.
Old Mar 19, 2013 | 08:02 PM
pwrtrip99's Avatar
2004 E55 AMG
I've attempted to attach the pictures of the old pump, and the non-fitting GMB unit, purely as an academic exercise.
Old Mar 19, 2013 | 08:14 PM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Is this standoff something that could be replaced by say a small stack of washers or if you had a chunk of metal about this size that you could machine/drill to work as a standoff?
Old Mar 19, 2013 | 09:29 PM
pwrtrip99's Avatar
2004 E55 AMG
I didn't want to be a guinea pig, so I opted to send the GMB pump back, and bought the reman OEM one from Pelican Parts.
Old Mar 20, 2013 | 10:08 AM
vntgspd's Avatar
Porsche 911
I believe that is more than a spacer/standoff. That is where the bolt for the supercharger idler THREADS in, correct. Not something you want to mess with since alignment of the pulley is very important as is the rigid mount.
Unless you are an unemployed machinist with tools in your garage, I doubt you could fab a suitable long term solution for less than the difference of the two pump prices.
