Bosch 010 installation question
1 Post
A4, M3, 996, E55
My Johnson CM30 died after 4 years on the car
Based on research here I opted for the Bosch 010 this time around
Problem is the factory connector for the pump is long gone from the cm30 install and with the connector on the Bosch pump its not a straight forward solution for install.
Does a anyone know a part number for the factory clip or have a good alternative solution for wiring into the connector on the Bosch pump?
Thanks,
Andy
Thanks,
Andy
That connector is a real biatch to get, even with the part number they screwed it up twice at 2 diff dealerships, make sure you make them understand what you want and actually bring the pump with you so they know
