confirming my e55 hella relay.
http://item.mobileweb.ebay.com/viewitem?itemId=170986459559
Ps. All the talk about airmatic behavior. Should I hear a buzzing or pump at when turning the car off? Forget about whether it should drop a little when off, that's up for debate.
http://www.rmeuropean.com/Part-Numbe..._1BC6D23B.aspx
This one after ordered came in about a day.
I need to listen carefully in the next few days. If I don't hear anything on shut down, I may leave it.
Also, thanks for info on buying. I called two dealerships and they both said they had the part. $20.00 and it was the updated one, not the one that came with it (Tyco?). Well decided to be safe. Bought it and it has Mercedes logo/name on box. And, it says hella on the unit itself.
Any ideas welcome but for the next couple if days I will listen carefully. Maybe then put it in, and keep listening to make sure its a good hella and not a bad one. I suppose we all should always be aware and listen after shutdown. But you said you never heard the pump keep on running.. hmmmmm..
Anyone everything try to wire it to the ignition, so it has to shut off when the car does?
Thanks again for all the info.
The one I got from mercedes (they said updated) looks like this: part 002 542 7219
http://thumbs2.ebaystatic.com/m/mnNf...bNXSDw/140.jpg
I found the following link and it has the one above and 002-542-1319
http://www.autohausaz.com/search/pro...nation%20Relay
Do I need to get that one too (1319)?
any other thoughts always welcome.
thanks
Ps. Question: Does using the ride height button allot OR changing from Comfort ride, Sport 1, sport 2 have any affect on how long before there is an airmatic problem? I find myself a little reluctant to change it much. I usually ride around in sport 1. Any one of them better or worse for it?
Last ? on this, I thought the air relay "O" was under the hood. But now I heard it behind the passenger side trunk panel?
Guess I am to unfasten the panel and check it out... any info appreciated.
