Just got my new pulleys, install help
05 E55, 07 ML500
Just put this kit on my car.. Where did you get it? Shardul?? That's where mine came from. When it was installed I was told to use all 4 shims PLUS the 2 OEM shims.. Was Not to spec and it thru the first belt on the dyno, then Miraculously it came into spec as Shardul said it would, still don't understand why.. Maybe he can chime in on this?? Anyway good luck on the install...
2005 Mercedes-Benz E55 AMG
Just put this kit on my car.. Where did you get it? Shardul?? That's where mine came from. When it was installed I was told to use all 4 shims PLUS the 2 OEM shims.. Was Not to spec and it thru the first belt on the dyno, then Miraculously it came into spec as Shardul said it would, still don't understand why.. Maybe he can chime in on this?? Anyway good luck on the install...![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
did u install it yourself or went to the shop?
called few shops, they all charge 150-200 for install, is it a good price?
