DIY Tail Lights Swap?
Hey guys, did a search, and this is all I could find
https://mbworld.org/forums/w211-amg/...il-lights.html
I got the E63 style DEPO lights and just wanted to see if there was a trick to taking apart the trunk liner or anything I should know.
Thanks!
Thanks!
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
nope just use a flat head screw driver with a rag on top to pull out the connections on the trunk as well as the trunk latch area.
YOU will have to remove the airmatic pump to access the passenger side. Use a thick book or something to support it on
Each taillight is held in by 5 10mm nuts, just pull the light towards you when done. Should come off.
Depo lights have the bulbs included so just plug and play
