Part #'s for bearings in the diff
Old Apr 2, 2013 | 04:33 PM
bstudey01's Avatar
2003 E55 AMG
Can anybody help me find a part number for bearings in my diff. Putting the quaife in this Monday and need to order them. It's an 03 so it has the w210 axles and diff. My vin is WDBUF76J53A391197 if it helps.
Old Apr 2, 2013 | 04:54 PM
Lawrence1's Avatar
2011 G55 + others
Your car might have the newer diff. Have you confirmed you have the w210 rear end before ordering the quaife?
No one knows when they changed the diffs over on the '03s. do you have bolt in axles? Because the newer style slide in apparently.
Either way please post here when you're done as i would like to see what the part number isbon your diff housing and what your axles look like to compare to my car.
I will look up the part number for you tonight when i get home.
Old Apr 2, 2013 | 05:01 PM
bstudey01's Avatar
2003 E55 AMG
Yes my axles bolt into the diff housing. I had the vin looked up before ordering the quaife as well. No luck so far on the bearings, I just got off the phone with two different dealers and they are unable to find them listed in their system.
Old Apr 2, 2013 | 05:10 PM
cm60k's Avatar
As i remember my friend ordered those bearings for his (2004 E55), "4" months ago, with an OE #: "002 980 17 02",,
you can also take yours as a sample, and go to any good bearing vendors , you will find a good brands like:
(SKF/***/NSK/NTN/KOYO/TEMKEN/NATCHI).....
ZAYED,,
Old Apr 2, 2013 | 05:23 PM
mertd93's Avatar
04 E55 B07, 11 CL63, 17 GLE63S
Old Apr 2, 2013 | 05:40 PM
bstudey01's Avatar
2003 E55 AMG
I just order 2 #6's and 2 #5's from this part's diagram off parts.com hopefully they are the right ones.
http://www.parts.com/parts/2002/MERC...6450&itemAdded
