Weistec E55
Old Apr 3, 2013 | 02:10 PM
ali saklaoui's Avatar
C32AMG.335 e92 fbo.protomotive996 gt2
Weistec E55
Hello Guys,
we just finished the installation of the Weistec SC kit on one of our E55,its amazing and very simple to install.The car is super fast and smoother than stock.it made 702hp on low boost and pumpgas.
Old Apr 3, 2013 | 02:15 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Very cool! I just put mine on last week too, I'm finishing up some other small stuff so I haven't started it yet. Is it loud?
Btw is that weistec's tune? Big spread in AFR from one pull to the next.
Old Apr 3, 2013 | 02:22 PM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
Is that calculated engine hp/tq? So 638hp max at the wheels?
Old Apr 3, 2013 | 02:26 PM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
Now I wonder how the "Shadul's smaller static supercharge pulley" will compare to this. Of course, it's unfair to compare but if it could net out 50hp from smaller supercharge pulley at a fragment $, then it's worth! Sorry for off topic
Old Apr 3, 2013 | 02:41 PM
Toadster's Avatar
2005 E55 AMG
yah, what's the math here?
either way - those are some stout numbers! what are IAT's like?
Old Apr 3, 2013 | 03:03 PM
BRABUS786's Avatar
Stage 3 63
Originally Posted by ali saklaoui
Hello Guys,
What other mods are done with the weistec charger
And what dyno did u use?
Acid
Old Apr 3, 2013 | 03:06 PM
hpV12's Avatar
Audi A4
Maybe some pics too...
Old Apr 3, 2013 | 03:19 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
So it did 638 hp at the wheels and 665 torque at the wheels on a dyno, then the other number at the engine were calculated by the dyno?
tbradley70's Avatar
aviator
702 is what it shows as engine power on the run with 638whp. That's using less than 10% drivetrain loss. If you use 15% loss then its 750 at the crank.
Old Apr 3, 2013 | 03:27 PM
blackbenzz's Avatar
haters crazy
Nice numbers!!! Can't wait to get mine tuned
Old Apr 3, 2013 | 03:51 PM
Robert AMG's Avatar
Cls63 & C32
This dyno is the only one here in Lebanon, the engine(crank) hp is 100% true, i measured alot of stock car on it with 100% stock nbs, so the 702hp is 100% right, but the wheel hp is high, to compare with US dyno it is something like 702/1.18= 600 WHP.
Ali, this number is not so high compare with our modded E55's with stock blower, if we want to compare, attached is a dyno sheet on the same dyno for an SL55 03 with 185mm pulley, 82 TB, Kleeman headers, 550cc injectors, stock intake with K&N, 2 HE's with meziere, Jerry dyno tune: 584*1.1=643 crank hp minus 702= difference 60 crank hp plus, from modded 55K to weistec 55:
Old Apr 3, 2013 | 03:54 PM
Robert AMG's Avatar
Cls63 & C32
now if we can go higher boost with the Weistec it is a different story!
Old Apr 3, 2013 | 03:56 PM
Robert AMG's Avatar
Cls63 & C32
if you compare the torque, the Weistec is way low compare to 185mm with Jerry dyno tune.
Old Apr 3, 2013 | 04:01 PM
BRABUS786's Avatar
Stage 3 63
Is that a dyno com dyno by any chance?
Old Apr 3, 2013 | 04:05 PM
Robert AMG's Avatar
Cls63 & C32
yes
Old Apr 3, 2013 | 05:18 PM
chawkins2001's Avatar
2006 E55 AMG
Good info right here finally. Interesting to see that the richest air fuel and lowest HP run held the power best up top by far. Power drops off quickly up top by leaning it out.
Definitely a BAWS
Old Apr 3, 2013 | 07:37 PM
RedBullJnky's Avatar
you to Hate
Hello Guys,
What other mods are on this car? and what was the boost?
Old Apr 3, 2013 | 09:14 PM
Gadget's Avatar
06 E55 AMG, 13 C63 AMG
Very nice!!
Do you know what dyno that is? I have not seen the data displayed that way before.
G
Old Apr 4, 2013 | 12:02 AM
The car is still running on low boost and conservative tune ,it is true that there is 60hp over the fully modded sl but look at the power band it is much better and Weistec can hold high hp till 6000rpm but with the stock blower HPs drops from 5000rpm.thank you.
Old Apr 4, 2013 | 12:11 AM
you to Hate
Not mine! I held 549whp through 7000rpms. Thank you very much!
What is your boost and what oct is your pump gas?
Old Apr 4, 2013 | 02:51 AM
Robert AMG's Avatar
Cls63 & C32
the SL is dropping hp only after 6000, peak hp is at 5900, but yes the graph is better for the weistec.
do you have the graph of Bilal E55? how she's running with top mount IC?
Old Apr 4, 2013 | 08:14 AM
ajm55's Avatar
2006 E55 AMG
Nice numbers.
What other mods?
What boost?
Are you running the Weistec tune?
Old Apr 4, 2013 | 08:51 AM
cij911's Avatar
one car at a time
Other than the AFR, the numbers and curve look very solid....gaining 60+ hp is a lot especially when on low boost...My guess is you'll get at least 10-15hp for every psi you add....Enjoy
Old Apr 4, 2013 | 09:59 AM
Originally Posted by ajm55
Nice numbers.
What other mods?
What boost?
Longtube headers
it is up to Steve to tell about the boost
yes it is tuned by Weistec
Old Oct 20, 2013 | 08:07 PM
mohamadaz's Avatar
This car was made by Ali saklaoui too 600 whp and this engine is installed on a clk w209 the car weight is 1650 kg with 670 hp cranck and 1208 Nm of torque so try to beat this .....
