bumer splitter and rear diffuser question
https://mbworld.org/forums/w211-amg/...0-shipped.html
Rear Diffuser
http://www.ebay.com/itm/150992801118...84.m1438.l2649
Rear Diffuser
Thank you, are they both from the same seller?
The one from Gary for the front diffusers are very well made, install is simple. For the price it can't be beat.
So, here's what I did.. got 3 rolls of the automotive grade 1/2 inch 3M double sided stick tape. Lined the mounting edges with tape and did a test fit. Marked it for alignment with blue painters tape and a sharpie so it could go on precisely when the tape protector was removed. On the underside, I drilled 1/2 inch holes that I ran seven (7) 3/4 inch long SS pan head screws to the underside with a washer - equally spaced. Rivited the trailing edge near the tire through the wheel well on each side. Sorry, no pic's of the plugs, but I can take if wanted. Just a plastic Home Depot plug in white that I painted black-underside of splitter is all flat-no screws showing. Just did a 'snug' level of tightness throu the plastic valence material.
Looks good. Very solid...til I hit a curb parking it on an Armadillo on the highway!
Hopefully, these pic's will help...
