Active Headlight motor replacement
Old Apr 10, 2013 | 05:02 PM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
For over a year i had the "corning headlight deactivated" error, this was being caused by a faulty motor in the headlight unit.
I could have deactivated the cornering function on the headlight but i actually liked it so i was about to replace the headlight (£675 from MB), but i read it could be repaired, so i thought id give it a go.
So off to German ebay where i manged to source a broken headlight unit for £50, hella part 1YL 158696-02 which you cannot buy even direct from Hella.
Unplug the 2 big plugs behind the headlight and removed the bolts and the headlight was out
After removing the light we have to remove everything theat can be removed, screws, clips, control units the lot
Remove
remove
remove the rubber drainage hoses
Unclip the cable on the ignitor, then twist the ignitor and pull it off, then remove the xenon bulb, and all other bulbs and holders
remove bottom fixing bracket
unclip the plastic cover and remove
Then carefully with a screwdriver pry off all the plastic clips around the lens
Then comes the scary part, preheat an oven to 100C, stick the light unit in and start praying!, seriously, keep checking every coupls of minutes for about 6 minutes, by this time the glue holding the lens will have warmed up enough to allow you to pry it off.
as i was reading this procedure from a US forum, i forgot cent and ferenhiet, so i had a soft headlight unit when it came out and the glue was very runny and went everywhere! hence i didnt have enough hands to take the pics
once lens is pryed off undo ths connector on the left
and this one at the bottom which fits into the ballast\control units
you are then left with the main xenon lens unit
As the replacement i had a LHD one, the lens cutoff is different, so i had to swap the lens frame over also, i then installed the fixed lens unit and put it on the car to test, it looked like something out of terminator!
NO MORE ERROR!
i put it on STAR and carried out the left and right test and it worked perfectly!
after this I cleaned up the mess on the lens where the black sealant went everywhere and bought a tube of the mercedes sealant which is used all over your car for gaskets etc.
removed all the bits off the light unit again and stuck it back in hte oven ot soften the bonding agent again, took it out and stuck the lens back on. I then resealed the light unit with the mercedes sealant.
I then put everything back together again
as an added step, i had to repair the lugs (as doofus had melted them in the oven), MB do a nifty repair kit which has all 3 lugs, i needed two.
i sawed the old melted lugs off and srewed the new ones back in
fitted the light back onto the car and 5 months later it works flawlessly, hope the above helps
Old Apr 10, 2013 | 06:00 PM
black06c230's Avatar
mgLipGD
Wow nice job!!!
Old Apr 10, 2013 | 07:08 PM
3BNick's Avatar
2006 E55
Great work! A real popular swap for these projectors is replacing the stock fresnel projector lense for a clear one. It really enhances the performance of the projector/xenon system and gives you a razor sharp cut off line. Since you have already managed to completely disasemble you should give it a go next time you feel so brave.
I have a spare set of E63 lamps I'll be doing a lense swap in soon.
Old Apr 10, 2013 | 07:52 PM
berti_00's Avatar
2016 Cls63s AMG
wow all that work... am glad i dont have that option
Old Apr 12, 2013 | 12:53 PM
harjothundal's Avatar
05 e55
Coming from a vehicle that had Honda s2000 projectors, the projectors in the 55 are really lacking due to the fresnel lenses (as mentioned above)
I'm thinking about doing this mod to enhance the sharpness of the cutoff:
http://customlightz.com/?p=p_169&sNa...-lens-swap-e55
It's a great cheap mod, and the effects will be quite noticeable, especially if you bend the cutoff shield and enhance the colorband..
Old May 15, 2019 | 09:48 AM
ScottyAC8DE's Avatar
E320 CDI
Originally Posted by Alps
For over a year i had the "corning headlight deactivated" error, this was being caused by a faulty motor in the headlight unit...
...fitted the light back onto the car and 5 months later it works flawlessly, hope the above helps
I know its been a while since you posted this. Could you tell if the gimbal/pivots could be cleaned and lubed when you had it open? While I don't get an error, what happens is that when it is really cold outside, one or both will stick in a downward direction. After headlamps can warm up and I shut off the car and restart, they will go back to normal. It's done this since the car was 2 years old and it is now 13 years old. Still does it and it is only intermittent. The stealership was never any help on this one. I'm getting ready to put new lenses on, so I figured this might be the time to have a look at this.
Scotty
