Radiator change and H/E hose upsize.
Old Apr 13, 2013 | 07:11 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Had to change the radiator out and this was no easy task. Good news is that Amazon had the Behr rads for about 285.00. While I had it out, also changed out all the small, bent up H/E lines that go to the blower and up-sized them to 3/4 silicone hoses.
Old rad
New Rad
There are two small kinked up H/E hoses, one for inlet and one for return. Both were changed out to improve flow and ease back pressure on the pumps.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Apr 13, 2013 | 08:36 PM
RedBullJnky's Avatar
you to Hate
Old rad
New Rad
That's funny! I just did this!
Old Apr 14, 2013 | 09:32 AM
EdoubleNickel's Avatar
SOLD 04 E55 Now 93 w124 3.2 sold W210 E55 sold waiting on W211 E63 p030
Damn.... I just changed my radiator also. Bumper over had to come off. Now my condenser is bad....attached to the radiator. Warranty will cover that.
Old Apr 14, 2013 | 11:01 AM
PLATINUM SPONSOR
2003 CL55
Anyone find a larger core rad? I ordered a CL65 rad but was the same amount of cores.
__________________
www.ultimatepd.com
Old Apr 14, 2013 | 11:12 AM
cij911's Avatar
one car at a time
Why would you want a larger core ? You should not be having cooling issues with a stock radiator (as I know you know).
Old Dec 16, 2016 | 07:06 PM
spastik monkey's Avatar
Veteran: Army
Chevrolet Traverse, Honda Cbr1000RR
Old rad
New Rad
Where did you source the hoses?
