Performance Springs for W211 E55 with airmatic?
Old Apr 20, 2013 | 09:15 PM
dlav06's Avatar
Dodge Challenger Hellcat Widebody, Porsche Cayenne, International Scout
Hey! I am getting my car track-ready and I'm looking to lessen the amount of body roll, and I was wondering if anyone had any recommendations for performance springs? I do have the Airmatic suspension and it seems like most springs I've found have not been available for cars equipped with airmatic. Ultimately, I wouldn't mind if the springs lower my car by an inch or so either. Thanks in advance for the help! I really appreciate it!
Old Apr 20, 2013 | 09:23 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you will need to get a coil over suspension and remove all the airmatic struts. about 600 dollars worth of related suspensions parts will need to be changed and the car has to be coded to steel suspension. quite a few members have done this.
Old Apr 21, 2013 | 12:23 AM
viren.89's Avatar
2004 E55 AMG
A member here got his car lap ready by lowering it using links and biggest change he said that improved his handling was putting 255/40 in the front . He said it improved the handling by "a lot"
Maybe getting a Limited slip differential as well not sure if it helps with cornering or not though.
What tires you planning to put on ?
Old Apr 21, 2013 | 12:39 AM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
coilovers are the best
Old Apr 21, 2013 | 02:47 AM
BenzoBoi's Avatar
Super Moderator
W221
All E55K's were equipped with Airmatic. You cannot put lowering springs because you are on air. You can either lower the car via star, lowering module, or the washer method. Another option is to completely remove the airmatic system as shardul mentioned earlier and swap out with a coilover system. Good luck with your decision!
