Custom Fuel Rail
First, what is the connector on the firewall which has a hose going to the fuel rail? 6an? 8an?
Second, is the pulsation damper necessary? What would be the effects if removed?
The plan is to run a new feed line into a Y then feed the engine from the back with equal length hose and also loop the front of the rail.
I have been welding for a long time and plan to pressure test the components before install.
Thank you
Thanks, I found this adapter as well as 1 on Pegasus website that goes from 14mm to 6an. My plan is to the go to 8an and run the rest of the line as 8an.
Will I loose significant pressure due to the volume increase going to 8an all the way to the rail via a 8an in Y adapter 8an out ?
http://www.extremepsi.com/store/product.php?productid=20907&cat=1712&page=1
