E55 block required.
Old May 1, 2013 | 08:34 PM
barlow100's Avatar
2012 E63 Bi Turbo
E55 block required.
Looking to buy E55 block.
Old May 1, 2013 | 08:47 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Stock block?
Old May 1, 2013 | 11:23 PM
barlow100's Avatar
2012 E63 Bi Turbo
stock.
Old May 2, 2013 | 09:53 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Originally Posted by barlow100
stock.
Bare block, assembled or one you want to build a short block from?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old May 2, 2013 | 01:34 PM
03'55AMG's Avatar
AMG
Depending on your wants/needs, BI-Performance may have what you need.
Old May 2, 2013 | 04:36 PM
barlow100's Avatar
2012 E63 Bi Turbo
Thanks, any suggestions appreciated. Tear down in the next week or so to determine damage.
Old May 2, 2013 | 09:21 PM
03'55AMG's Avatar
AMG
Contact BI-Performance or Chawkins. He'll take care of your needs.
Old May 3, 2013 | 07:21 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
i've got an assembled motor minus s/c that started to get some blow by on #8. it still ran strong when it was pulled so i'm sure besides cylinder honing the block is in good shape.
