Rear Sub Frame Bolt - It's not a big deal.
Old May 4, 2013 | 06:43 AM
GregMB's Avatar
Originally Posted by 03'55AMG
what size tap should be used to chase the threads?
I don't know the specifics on that thread, but remember there is a difference between a tap that cuts new threads and a tap for chasing threads...
You don't want to use a cutting tap for thread chasing, as it will remove additional material. The end result will be an even sloppier fit of the bolt, and lower ultimate clamping force.
-G
Old Sep 9, 2013 | 02:49 PM
GregMB's Avatar
Btt
Are there any symptoms besides the "dead body thump" that are attributed to broken subframe bolts?
I've had 3 alignments in the last few months and still can't seem to 100% resolve a "wiggle" in the rear end under full-throttle. It's there up through 80mph and can quite disconcerting... At moderate throttle I don't notice anything... Occasionally I think I hear a minor bump out back... But so far it's only rarely there.
Thanks guys!
-G
Old Sep 9, 2013 | 03:20 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Greg
You can peak under the rear off the car without a jack and you will be able to see all 4 mounting points
Old Sep 9, 2013 | 03:24 PM
GregMB's Avatar
Thanks Shardul!
So if one of the bolts is broken will the bottom half of the bolt have probably fallen out, or is it likely to still be in there? I'm just curious how easy it will be to see actual breakage if it happens inside that bushing area with the subframe possibly blocking the view?
Old Sep 9, 2013 | 03:30 PM
shardul's Avatar
Originally Posted by GregMB
Thanks Shardul!
it may be missing the bolt and you when you compare it to the other side the sub frame will be lower. you will be able to put your fingers between the chassis and the sub-frame.
Old Sep 9, 2013 | 03:46 PM
GregMB's Avatar
Cool... Thanks. Sounds like it will be easy to recognize if there's a problem.
Does the squirminess I described sound like a symptom of a broken bolt based on your own experience?
-G
Old Sep 9, 2013 | 04:12 PM
  #32
shardul's Avatar
-G
not really I had the same issue and it was solved after alignment
Old Sep 9, 2013 | 04:32 PM
  #33
O-55's Avatar
2005 E55, 2009 VW GLI
-G
I'd have your toe link bushings checked out if your car feels like it is "steering" from the rear.
-Oscar
Old Sep 9, 2013 | 11:01 PM
  #34
marcmaddox's Avatar
2005 E55 AMG, 2012 GL550, 2000 Ford Lightning, 2005 Chevy Silverado 2500HD
If these bolts do have a torque spec followed by a degree turn they are torque-to-yield and should not be reused. That would explain the failures after removal and reinstallation. I worked in a service shop for 20 years and I could count the times on one hand I saw a tech use the correct torque method on this type of chassis bolt. 99% of the time they simply hammer them in with a impact.
Old Sep 10, 2013 | 05:22 AM
  #35
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Here in Germany every nut or bolt that has a torque spec is always properly tightened with a torque wrench.
Old Sep 10, 2013 | 07:42 AM
  #36
GregMB's Avatar
-Oscar
What's weird I'd that I now have a new set of MBArts toe links in there....(solid heims and round tubular links) so the stock rubber bits aren't there anymore to cause toe changes.
At first when my car was lowered, I thought the excessive negative camber might be complicating things. But this last go around with alignments I disabled the ELM and put the car back to factory height before the alignment.
Puzzling...
-G
Old Oct 17, 2013 | 02:13 PM
  #37
Denroll's Avatar
'06 E55
Here's some pics I took yesterday. This is the second time this has happened to me; first time was on passenger side, this time on drivers side. The bolt ripped out of the frame both times.
Went to the most awesome local hardware store (Marshall's Industrial Hardware) with the old MB bolt in hand. Measured the thread pitch and diameter and picked up a hardened steel version a little longer than the stock bolt. Also picked up several heavy duty washers and some nuts for the bolt.
Remove the wheel and the plastic fender liner and then you can access the frame. My mechanic used two plates of steel with a hole drilled for the bolt. He did it in less than 30 minutes. Parts cost was around $6. I paid $11 because I always buy extra when I go get little pieces of hardware.
Old Oct 17, 2013 | 02:48 PM
  #38
black06c230's Avatar
mgLipGD
How hard is this to do as preventive maint?
Old Oct 17, 2013 | 03:22 PM
  #39
Denroll's Avatar
'06 E55
Not too bad. Cut an access into the frame like pictured, get a good look around, remove the bolt, reinforce the area, install new bolt. Don't reuse old bolt. It's a torque-to-yield (a.k.a. stretch bolt) designed for a one-time use. Like the crank pulley bolt.
I'd say an hour tops per side for the handyman with the correct tools and materials.
Old Oct 17, 2013 | 03:31 PM
  #40
taurran's Avatar
04 E55 AMG, 03 350z Track Built/Single Turbo
Is there any other symptom of this issue besides a terrible noise?
Would one side of the rear suspension be hanging lower when the car is off the ground?
Old Oct 17, 2013 | 03:51 PM
  #41
Denroll's Avatar
'06 E55
When my passenger side went, the right rear of the car was way up in the air, like the bag had fully inflated. Nothing like that on the left until I raised the car with the button.
Both instances were met with a fairly loud pop. Definitely something you would notice.
Old Nov 17, 2014 | 12:09 PM
  #42
gni2002's Avatar
2007 E350 > 2007 Honda Odyssey>2006 Porsche 911 S
Good all,
I'm flabbergasted. A quick recap. I have 07 W211 E350 sport (staggered wheel layout) with OE specs. 2 days ago, an incident took place on my driveway. As I was driving home, approaching my driveway, I heard and loud "thud" as if I ran over a pothole. no potholes where I live nor did I ran over anything. After inspecting the car, noticed that the rear is low, 1/4 of the rear top of the tire is tucked in the wheel well and negative camber to the extreme. Jacked up the rear and to my surprise, 2 bolts long bolts fell, seems to have sheared off. It came from rear sub-frame bushing. Another member here in the forum, ECsquared has experience this issues. I do not carry any heavy loads, I have a toddler I shuttle around. I do not race, track the car in anyway, it's currently at the dealership and I just got their labor and part quote for, get this, $1450.34.... WHAT!!! for 2 bolts that are designed to hold a rear subframe, price seems extreme. I'm very disappointed with this brand...Any insights?
Old Nov 17, 2014 | 12:16 PM
  #43
shardul's Avatar
it is a 1 hr fix per side if you know what you are doing and about 10 dollars in parts
Old Nov 17, 2014 | 12:30 PM
  #44
gni2002's Avatar
I've been following and reading all inputs from this forum regarding this issue and I'm confident with my know-how that I can do it with the guidance from this forum. Unfortunately time is not on side. I did buy an extended warranty and hoping this is something they cover....I still in awe on how that happens. It's not reassuring, particularly for this brand, and I'm very disappointed.
Old Nov 17, 2014 | 03:01 PM
  #45
kponti's Avatar
E63
You keep referring to "this brand" hope you now that this brand does have reliability lower than a GM in a lot of cases right?
Old Nov 17, 2014 | 03:50 PM
  #46
2000UZJ's Avatar
E55
Old Nov 17, 2014 | 04:06 PM
  #47
£ C43 £ AMG £'s Avatar
E55K AMG
Sub frame has come away twice.
first time was the worst and caused a fair amount of other damage, both cavity threads were ripped out.
https://mbworld.org/forums/w211-amg/...y-chassis.html
second time bolt snapped
Old Nov 17, 2014 | 04:32 PM
  #48
gni2002's Avatar
touché my friend
Old Nov 18, 2014 | 12:15 AM
  #49
kponti's Avatar
E63
Lol good responses!
Old Nov 29, 2014 | 07:36 PM
  #50
macbryanie's Avatar
Porsche 2004 911
C32 has joined the club. Torn at subframe (lefthand side) . Cutting an access area to weld a replacement. Only plus is quaife will go in as the whole back end is off. lolz.
