gauge turns RED at take off??
so twice today when taking off in manual mode the gauge speedo gauge turned red. It was for a split second and i couldn't make out what it said. Can anyone shed some light on this? thanks in advance.
it would remain red in most cases but am not 100% on if it will go away as it does with driving with an open trunk or w.e it will show red than if u ignore it will keep on going than it goes away
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
I would say alternator is on it's way out....when it doesn't receive the correct voltage it will display a message and make the dash red.
Had that happen to me and the alternator went soon after. It was noticeable on take off then went right away...
no not at all,I had a bad aux battery in the engine bay and would make the red dash come up every now and then,checked the voltage and it was like 8-9volts and replaced it with a bike battery that fit in the spot and it went away for years after I swaped the aux battery out
