80mm TB breather hoses
i just recently purchased a e55 and turned out to be a Kleemann k-4 car.
I have been fixing random things like valve cover gaskets, trans connector,motor mounts
after looking the car over I notice the to valve cover breather hoses meet each other with a t- type connection and then a 8mm plastic hose goes to the top of the supercharger on the second port. the other port has a small rubber 90 with a small plastic line that goes under SC and hooks up to the valve in front
I have seen most peoples set up and does not look like anybody is using the second port when installing 80mm TB it appears to be plugged.
So my question is where are you guys hooking the breather hoses to?
did it normally t-off and hook to the factory TB and the 80mm does not have the port for it.
