clunk on the front driver's side
Old Jun 1, 2013 | 12:39 AM
Toadster's Avatar
2005 E55 AMG
sometimes when going over bumps or just unloading the brakes, there's a clunk in the front driver's side
brake caliper? tie-rod end?
not sure - just had the thrust bearings replaced a few weeks ago.
Old Jun 1, 2013 | 01:03 AM
V TO E55's Avatar
05 E55/08 C6 Z06
I'm going though that right now..I changed the front left wheel bearings and it stopped till the car starts getting warmer
I think it mite need adjustment..
Ill keep you posted
Old Jun 1, 2013 | 02:46 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
A ball joint in the twilight of its life can make sounds like that..
Old Jun 1, 2013 | 04:03 AM
V TO E55's Avatar
05 E55/08 C6 Z06
Upper or lower?
Old Jun 1, 2013 | 05:26 AM
Aljulanda's Avatar
ML 350 AMG 2010
Hi guys.. I just joined the forum for the same reason as I have the same problem
It started about 2 weeks ago and I usually get the knocking / thumping sound when driving at low speeds or when I park the car
Highway driving is as smooth as silk
I went to the dealership who asked to keep the car for testing for 3 days
Unfortunately I didn't have another vehicle so I scheduled it for next week
Keep me updated please
Old Jun 1, 2013 | 05:51 AM
MindBend's Avatar
'05 E55
"3 Days of testing..."??
I'd ask if one of their techs are planning a vacation with it! That's downright silly.
Old Jun 1, 2013 | 06:46 AM
Could be either but lowers typically go out first.
Originally Posted by V TO E55
Upper or lower?
Old Jun 1, 2013 | 07:26 AM
1970gsx's Avatar
'06 E55
Put it up on jackstands and try and move and wiggle front wheels around. You will see/feel the movement, and will know if it's the upper or lower ball joint or any other worn out part.
Old Jun 1, 2013 | 08:11 AM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
i have the same problem it is the sway bar bushings.
Old Jun 1, 2013 | 08:12 AM
MindBend's Avatar
'05 E55
Bushings
Yep. My E and CLS both have had the crunching/creaking driver's front: turned-out to be the bushings.
Old Jun 1, 2013 | 09:34 AM
Karlson's Avatar
06 E55
Upper or lower?
lower
Old Jun 1, 2013 | 09:46 AM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
I have a creaking(tie rod) and a clunking(lower ball joint) and have an appointment to get them repaired plus replace my Cooling pump
Old Jun 1, 2013 | 09:57 AM
Manuyc's Avatar
Originally Posted by Karlson
lower
its the sway bar bushing the only bushing that is bolted to the frame of the car. it has a long black bar running across the driver side to the passenger side of the front
Old Jun 1, 2013 | 12:31 PM
Toadster's Avatar
2005 E55 AMG
if it's bushings - are there better parts to use to replace? or just use OEM ones?
Old Jun 1, 2013 | 12:40 PM
Thanks for that tip I'll keep that in mind. That wouldn't have been the first place I'd have looked when mine eventually gets that noise
Old Jun 1, 2013 | 02:06 PM
V TO E55's Avatar
05 E55/08 C6 Z06
That's what I thought mine was till I removed the end-links and was hearing the same thing..
I could hear and kinda feel the same clunk from the steering wheel as I gently move the steering right to left when parked or stopped at a light.
I tried raising and lowering the car and it does not go away..
After I changed my front left wheel bearings(could not remove the inner race so I cleaned and reused) now I can only hear and feel the clunk only when I drive for a few miles.
Thinking it needs adjustment after it warms up
Old Jun 1, 2013 | 02:51 PM
Manuyc's Avatar
Old Jun 5, 2013 | 11:51 AM
Aljulanda's Avatar
ML 350 AMG 2010
And FINALLY...
The Dealership replied with the solution
They said that the bearing and the control arms (both upper and lower) have to be changed and after that they will see if the problem is solved..
In other words they slammed a 5000$ bill in my face and said that they will keep slamming me with more
My car is a 2010 model,, purchased in April 2011
It has 34000 km ONLY
no off roading and strictly no nuisance while driving
Warranty expired about 2 months ago
The service agent said that he will try get in touch with the manufacturer regarding a "good will"!!! Which I do not know what he means
Anyhow I took the car to another workshop "certified Merc mechanic" for a second opinion
Any feedback guys!!!
