DIY- E55 Alternator replacment
On the other hand in leveraging the alternator from its mount I broke the plastic idler pulley. The one that has the double pulley just above the alternator .... was not a happy chappy. Anyone know where to get a good replacement? is there an aftermarket upgrade that is better quality than the OEM? I need to order this asap as we are going on a road trip with the family Friday morning and need to get a replacement fast.
Tried to load my pictures of the burnt alternator but would not load, I'll try to load these again later tonight.
Alternator is scheduled for delivery this morning and will try to document with pictures the install on how I get it in with out removing/draining cooling system
What went out on your alternator? Was it the voltage regular or something internal?
It was a major pain and i did end up pulling the radiator hose to clear the alternator out.
One working is be mindful of the radiator support bracket. Under the bracket is the wire to open the hood and those clips need to be removed or you can run the wire off track and then the hood does not open.
. Also while you in there get a new belt and tensioner if it's within you budget. I wish I did because now I need to go back in there to replace those items
