Lightweight beehive valve springs for your M113K Mercedes
It's just a bit more research to find the best bead size for the 7 degree locks (for a valve stem of the right size). Those are the main pivots.
Keep the info active. Their will be guys that your info will help in the future.
The valve locks are my concern, as we spoke about several months ago. However I did speak with ferrea and they said as long as there is a true “lock” physically that you can feel, then I should be okay.
I’ll have the machinist do the ID increase on the valve spring seats. Other than that, I can put the rest of the long bloc together when I get the heads back and start working on the rest of the 10 things I need to do to have it back on the road!
The valve locks are good to go, Ive never heard of anyone having a problem in any of the engines I’ve built for people or from DIYers who had hit me up for tech help back when I posted this guide up.
The constant pressure from the spring makes the vertical play in the lock/valve groove radius irrelevant. It’s impossible for the lock to slide up and down in the groove of the valve stem while in operation, but if it were, the locks would just fall out of the retainer instead of that tiny bit of play in the groove doing anything problematic.
What’d you go with for cams?
What do you think you can increase the rpm to ? 7,000 ? and still make power?
If I can’t I’ll just run stock cams and know I won’t have the valves hang open.
Open to suggestion. I don’t need a higher rpm range but I did use arp rod bolts.
I was expecting to run quite a bit of boost (I have a 180 crank pulley and no current purchase on the SC pulley). I have to look again at the calcs - its been a while.
Where did you get the ARP rod bolts from, and what is the part number?
Check out Cat Cams. They have a few different options for the m113, including forced induction. I'm thinking of going with their 'hot street - dirt track' cams. Not cheap though. Sometimes you have to pay to play...
Everything else (head casting, spring pocket depth, valve length, is identical.
One set uses a spring seat with .290 overall height and the other uses a setting seat with .196 overall height.
Both spring seats have an identical pocket depth of .159 so the thicker seat comes with a shorter spring. I have no idea why they did this but the longer spring has a red/white stripe while the shorter one has two white stripes. The shorter springs will have the taller seats which will either need to be machined to the shorter height of .196, or swapped out for the shorter spring seats to give the proper 1.47 installed height.
I have 8 sets of 55k heads here and 7 of them have the taller red/white spring with the 1.47 installed height. The set with the shorter white/white spring is from an 04 CL55. @BC928 has an 06 E55 with the shorter white/white springs, and the heads I used for this write-up were also from my 06 E55 and they had the taller springs so there doesn’t seem to be any consistency since they all have the same head casting of R113 016 24 01 and R113 016 25 01.
These beehive springs will work with either, just make sure you’re aware of the spring seat differences.
PM me if you want to go that route. I paid $450 for each set, I’ll sell for $350/set
Shim the spring seat by .030 (IIRC) and you’ll get a little more seat pressure from the stock springs to help combat high RPM valve float, just at the expense of lift range before coil bind.
Youre better off with the beehive springs though. Lighter weight than even the Ti retainer OEM springs, better harmonics, and the capacity for increased lift in case you decide to try something more aggressive with cam profiles.
