ECU\SMOG\DRIVE CYCLE
Old Jun 17, 2013 | 03:47 PM
inferno2469's Avatar
OK, so i'm trying to smog my 05 and the ecu was set back to factory. i've driven 100+ miles on highway, street, over 50mph for ten min, etc. BUT my codes are still not showing up for "02" and "HTR". any idea how to get these to register??
Old Jun 17, 2013 | 04:12 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
it took my car about 400 miles and 3 weeks to reset all monitors.
Old Jun 17, 2013 | 05:49 PM
WAH?? really? There is no "trick" to get the data back in there?
Old Jun 17, 2013 | 05:59 PM
320 dreamer's Avatar
2003 porsche 996 turbo
To perform an OBDII Driving cycle do the following:
Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 50°C (122°F) and within 6°C (11°F) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
Old Jun 17, 2013 | 07:47 PM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
You have tune? If you do, talk to your runner to have the rear o2 turn on.
Old Jun 17, 2013 | 07:57 PM
No, back to a stock tune on ecu.
