Disable iPod to aux help. E63 08
Old Jun 20, 2013 | 11:10 AM
gtr886's Avatar
E63 W211 08, C32 W203 02
Unhappy Disable iPod to aux help. E63 08
Hi guys,
I just upgraded from a c32 to e63 yesterday.
I have done some research about the aux input being disable if I have the iPod connector. Is there a DIY or info on were I can re- enable the aux connection and just remove the iPod cable from the amp? When ever I select aux from audio menu, it says "aux no iPod"
Can you guys provide some kind of DIY info or where I should start?
Thanks!!!
Old Jun 20, 2013 | 11:22 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
remove the comand unit and you will have to swap the connectors.
Old Jun 20, 2013 | 12:36 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Reverse this,
https://mbworld.org/forums/w211-amg/...d-install.html
You will need to get the I-pod off the CAN /MOST buss so that MFD displays AUX only.
http://www.mercedestechstore.com/pdf...2009-03-02.pdf
Old Jun 20, 2013 | 04:24 PM
gtr886's Avatar
Originally Posted by Yacht Master
Reverse this,
Thanks, Does that mean I can just switch the ipod cable back to the aux? form the look of it, do i need to downgrade/ uninstall the ipod software? or is this a straight forward process?
Thanks again.
Old Jun 20, 2013 | 04:57 PM
shardul's Avatar
like i said straight forwad just swap the cables and be done it with it
