Anyone knows what this part is called ?W211E63 AMG.
Old Jun 21, 2013 | 02:45 AM
nysid2007's Avatar
08 E63 AMG
Hey Guys ~
Just wondering if anyone had to replace these two hoses that I highlighted.
Seems to be kinda hard to locate the part number.
Any idea is appreciated.
Thank you.
Attached Thumbnails Anyone knows what this part is called ?W211E63 AMG.-20130620_2324378.jpg
Old Jun 21, 2013 | 04:17 AM
rgracin's Avatar
2007 E63 AMG Wagon, 2003 Porsche 996 Turbo
Nope, but it's difficult to identify from that close up. Do you have a picture to show where it is located under the bonnet? Why do they need replacing? If you take it off, they might have the part number on the hose somewhere.
Old Jun 21, 2013 | 07:46 AM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
I believe each piece has its own pn on it. They mix/match hose connectors on all engines. Pn should be written on it as either A--- --- -- -- or just --- --- -- --
Old Jun 21, 2013 | 05:17 PM
Shifter's Avatar
E55, SL63, ML550
Don't know the part numbers but those are for secondary air injection the one that plugs into the intake manifold goes to the solenoid. The other runs out to one of the valves. You could just use generic rubber vacuum line if you had too b
Old Jun 21, 2013 | 09:35 PM
Lelix's Avatar
2003 E55
Red one is a generic vacuum hose with a check valve(blue piece).
Green ones are switchover valve hoses.
