A few issues with keyless go...
Weird, also the rear trunk manual latch is not working. I found that it was stuck and no idea how to reset it. I tried my hidden key but no luck. The trunk opens with my keyfob and interior switch but not with the latch.
Any ideas? Thanks for your input!
I guess I'd only really be interested in seeing how much dissasemby would be required to fix it.
Both issues can be resolved in one afternoon for not a lot of money (relative to other AMG parts)
Just ordered a full black handle for 120 bux to my door off Ebay, and hopefully I can get back to opening doors for passengers "the cool way"
I felt really stupid after figuring out mine was that easy to open.
As I posted in the other thread, I had somewhat of the same problem for a while. I ended up inserting the key blade, and slowly rotating it through the full range of motion while feeling the handle for tension. Mine will engage somewhere in the middle of the range of rotation. When you hit the sweet spot angle with the key, you should "feel" the handle stiffen up like it has spring tension, and it will open when you pull on it.
Forgot to add, the handle doesn't spring back to the start postition at all. It stays in the "squeezed" position.
