Lower Control Arm Installation
Old Jul 30, 2013 | 09:25 AM
FinanceMike's Avatar
CLS55
My thrust bushings are worn on my CLS55. I got a price of $425 from the dealer for a "bushing kit" and labor. This would ultimately still leave me with a used ball joint. I am leaning towards the aftermarket where I can buy a new lower control arm with the bushing already pressed in and a new ball joint for around $125 a side.
How difficult is this install? I imagine it is much easier than having to press in a new bushing.
Thanks.
Old Jul 30, 2013 | 06:56 PM
Dawson718's Avatar
E552004
www.parts.com
Old Jul 30, 2013 | 07:32 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
Thanks.
Give me a part number, I have a couple low mileage control arms laying around.
Old Jul 30, 2013 | 08:47 PM
CLS55
211-330-44-11
211-330-43-11
I am also asking about the install. It already has the bushing pressed in so I imagine it isnt too bad.
Old Aug 1, 2013 | 10:24 AM
groove66's Avatar
2005 e55
install is actually pretty easy.
1.Take out bolt where the thrust arm bushing is( don't forget to buy the eccentric replacement bolts)
2. loosen or take off the ball joint nut..
3. let arm hang
4. get baby sledge and whack the back of the control arm(where thrust bushing is) towards the ball joint. remember hit the arm not the bushing. it will fall right out. it may take a few whacks.. or use ball joint separator or air hammer with pickle fork.
I personally do it the sledge hammer way and takes 20 min a side on a lift..
Old Aug 1, 2013 | 10:46 AM
novae500's Avatar
W211
You can rent the tools to remove the LCA/thrust arms at your local auto parts store or purchase one on ebay.
Use an impact wrench w/proper socket size to loosen the LCA and reinstall new one. And get alignment afterwards.
