Got the CTS-V...comparison to my 2004 E55
Old Aug 22, 2013 | 01:26 PM
  #126
Tremek's Avatar
'17 GLS 63 AMG, '08 S65 AMG
$650 per side for the front axle's 370mm rotors on the Turbo S. The Turbo has different brakes (355mm I think?) that are much, much cheaper.
Old Aug 26, 2013 | 12:49 PM
  #127
PetroC63's Avatar
2012 CTS-V
Originally Posted by chawkins2001
That is hella fast for the minimal mods man I am blown away, did not know that for simple mods on pump gas these were 10 sec monsters. If you dont mind me asking, what did the mods cost to get you into the 10's?
Full weight?
Thanks.
$4,000 for parts and labor. Car is full weight.
Old Aug 26, 2013 | 08:41 PM
  #128
60nomad's Avatar
2011 CTSV auto, 06 E55 white pano, 87 Grand national, 63 split window
Originally Posted by PetroC63
Thanks.
Is your car an auto or stick...I imagine it is an auto. What did it dyno?
Just curious about the dyno bc my car dynoed low but if I recall correctly...your car dynode low too. My tuners dyno is stupid low on numbers!
I was also wondering what the auto V's dyno in stock form or with just exhaust and/or cold air?
Old Aug 26, 2013 | 08:50 PM
  #129
AMG E Power's Avatar
E55 amg
From what I've seen auto Vs dyno around 450-460whp
Old Aug 26, 2013 | 09:06 PM
  #130
PetroC63's Avatar
2012 CTS-V
I have an auto.
Mine came to 483rwhp and 504rwtq after mods on a low reading awd Mustang dyno with snow tires on the car.
Old Aug 26, 2013 | 09:16 PM
  #131
60nomad's Avatar
I have an auto.
I guess I don't feel so bad...mine came back 515rwhp and I forgot to ask the torque...lol...I pick it up tomorrow but again...his dyno is low and I will find out what type of dyno it is but it is an AWD dyno. I think those AWD dyno's are lower no matter what the name is of the dyno. I will post the type of dyno tomorrow and tq #'s...most importantly I will run my buddy tomorrow and see the difference.
Old Aug 26, 2013 | 09:18 PM
  #132
E55 amg
I have an auto.
Strong !
Old Aug 26, 2013 | 10:14 PM
  #133
PetroC63's Avatar
2012 CTS-V
It's probably a mustang dyno.
I was disappointed when I first heard my numbers too. I was expecting more but my first trip to the track made the numbers irrelevant.
Mustang dynos are load bearing dynos which are better for tuning. A load bearing dyno gives the calibrator the ability to hold the engine at one location while he refines the map of the surrounding area.
Dynojets are inertia driven dynos. They calculate by measuring how long it takes you to accelerate a known weight (the rollers). This makes it difficult to hold the engine steady at all the necessary map locations and build a detailed map.
Here is a quote from Greg Banish who's tuned quite a few cars in his day.
The added benefit to a load bearing dynamometer is that when it comes time to test dynamic conditions, the rate at which the engine sweeps across the RPM range can be adjusted to match exactly what happens in the real world. This means that the amount of time it takes to complete a run is the same between the track and the dyno. We have a better idea of just how much heat and load the engine will see on the street or track. In today's world of handheld flash tuning devices and "canned" tunes designed to fit a wide array of cars, testing under these real world conditions can make difference between "That should have been fine, I don't know why it broke at the track," and "Everything performed just like we expected" when the car comes off the dyno.
Originally Posted by AMG E Power
Strong !
Thank you.
Old Aug 26, 2013 | 10:29 PM
  #134
Hotsoss's Avatar
Current: Cadillac CTS-V (V2), Chevy Cruze Past: E55k
Good numbers.
Old Aug 26, 2013 | 10:54 PM
  #135
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Thank you.
Not all dynojets are only inertia driven. http://dynojet.com/automotive_dyno/i...vidual_lrg.jpg
Old Aug 27, 2013 | 04:45 AM
  #136
60nomad's Avatar
I have an auto.
I am a little puzzled that your car made a higher torque # then the HP #. On a V, I didn't think that happened too often.
I will have to get the full numbers that my car made later on and post them.
